Kubot MX5200 vs MX4800
   / Kubot MX5200 vs MX4800 #1
steveo1820
Round Rock, TX
Massey Ferguson 165
Anyone have any experience on jobs a MX5200 can handle that a MX4800 cannot? I'm seeing a price gap that makes me think I could get by with a MX4800 instead of the MX5200. I will be getting one with a loader + 4WD, will be mowing about 40 acres with 6ft shredder, planting 2-5 acres of food plots, + misc utility work. I want a tractor capable of moving round bales of hay, but do not plan to operate a bailer.
   / Kubot MX5200 vs MX4800 #2
I don't have experience with either tractor, but looking at the specs the only difference appears to be a turbo charger on the 5200 to give about 5 more HP. The transmission offerings and tractor weight appear the same. I would think that the 4800 would do fine knowing that on some jobs or in tough grass you might have to go a little slower on the 4800. Traction would probably be the limiting factor with ground engaging activities and I doubt you would see any difference there.
About how much difference is there in the price?
   / Kubot MX5200 vs MX4800 #3
May want to look at threads on the MX5100 vs the MX4700 - (they are the old version of what you are looking at) and everything basically still applies.
Good luck and hope you find the one that works best for you
   / Kubot MX5200 vs MX4800 #4
The extendable 3-point arms are very nice to have, but it would be difficult for me to put a dollar figure on it.
   / Kubot MX5200 vs MX4800 #6
Isn't there an upgrade kit for that?
(extendable 3pt arms). If there is an aftermarket mfg for these, I sure would like to know.
   / Kubot MX5200 vs MX4800 #7
You can do just fine without the extendable arms. They are nice but you can live without them and I would not buy aftermarket extendable arms.
You will barely notice the difference between the 4800 and 5200. Basically same model with a turbocharger and a higher price tag. I would like to buy a 4800 if I could find a good one around here. Would work alongside my 5100
   / Kubot MX5200 vs MX4800 #8
Oh I can live without extendable arms. It is the wife that complains about all the kicking and cussing. Still curious if there is an aftermarket mfg.
   / Kubot MX5200 vs MX4800 #9
Would the telescoping link arms even be an issue if the OP were to use a Speedco-style quickhitch? I haven't used them on my NX4510 since adding a QH.
   / Kubot MX5200 vs MX4800 #10
Actually, the non-adjustable ends would likely work better with a quick hitch.
You can buy the "Pat's" style aftermarket adjustable ends if you were so inclined. It can cause other connection issues
so read up on it first.
Towable Centrifugal Water Pump (A59228)
Towable...
1997 WESTERN STAR DUMP TRUCK (A60430)
1997 WESTERN STAR...
Teak Wood Dining Table (A59231)
Teak Wood Dining...
Bobcat 873 (A55272)
Bobcat 873 (A55272)
2002 Frieghtliner Pressure Digger Truck (A55973)
2002 Frieghtliner...
KOMATSU WA270 (A58214)
