rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,538
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
I have, several times. Its a "problem" that we're basicly unable to duplicate. We sold 28 standard L's last year and I can't name on person who has complained about this. I suspect the OP probaby has an 0-ring out causing the system to suck air, but on a properly working machine I can't seem to make the 3pt jerk around unless I open the drop valve up the entire way and shove the implement up and down.
I might be able to help on this. One of the problems with hydraulic system design is how to design pressure release port. Particularly that of configuring them to avoid low pressure zones where the fluid can vaporize for an instant. That's always a consideration when hydraulic cylinders hold up a heavy load that then needs to be lowered. Like a 3 pt. cylinder where there is a high gravity load. It's has to do with the vapor pressure of hydraulic oil. You'll also see the problem in FEL bucket cylinders...and especially where there is a lot of load out away from the pivot point .... like happens with some pallet fork attachments.
What happens is you go to let the load down just a little, and no sooner does it begin to move than it suddenly drops a little farther than intended. For an instance it is though there is no resistance. In fact, that is exactly what is happening.
rScotty - an old retired engineer
