Kubota has upgraded HST Fan Protection
   / Kubota has upgraded HST Fan Protection #21
Kudo's to Kubota. This newer one is much better than the previous which was way better than the original, which was none..... :D
But, be cautioned not to get a false sense of security with it. You still need to be cognizant of the situation your operating in. A damaged and leaking HST oil filter will do far more harm to an HST than a damaged fan will......
I run a home made steel skidplate whenever I operate without the MMM installed and on two occasions twigs have still managed to make their way up to the fan. Luckily on both occasions the twigs only made a noise and did no damage. Admittedly I was doing some serious grubbing with debris laying all around. As hoped, the skidplate has thus far kept the big stuff away from the vulnerable vitals.
Theres been times when I've run for hrs with the skidplate installed and so far I've not encountered any HST overheating issues or any other issues for that matter, for well over 5 yrs and 400+ hrs. I also like the idea that the HST filter that hangs down in harms way has some steel between it and the whatever lurks on the ground below it :D
IMHO, if one is going to operate in an environment where the BX is traversing over and around scattered debris sans the MMM, you absolutely NEED the protection of a skidplate.
Do you have anything to protect your steering linkage; loaned mine out and it came back with a torn boot.
   / Kubota has upgraded HST Fan Protection #22
You guys all have me convinced. I don't even have my BX2660 yet but I just ordered the Read Skid Plate and Steering Guard from Bro-Tek. It didn't sound as if I even wanted to venture out without the added protection.
   / Kubota has upgraded HST Fan Protection #23
I think I am going to do the same thing and may get the front skid plate; probably take them off in the summer.
   / Kubota has upgraded HST Fan Protection #25
Typicaly we give a pretty hard pitch that guys who need to be worried about things like skid plates, should be considering a B-series tractor. The BX can do a lot and I know for many of you its the right fit.. just be careful and remeber its a tractor... not a bull dozer.
   / Kubota has upgraded HST Fan Protection #28
I would think that you should be able to run a BX through the woods. I put a Bro-tek skid plate on the back and made one for the front after my neighbor hit a stick in his yard and broke the fan on his BX24. Just piece of mind.
The BX fits my property and fence setup better than the B series does which is what I was originally looking at.
Deano
   / Kubota has upgraded HST Fan Protection #29
I just received the guard from Kubota....I ordered it from Lulich Impliment in Mason WI...It was drop shipped to me from Kubota. Cost with shipping was $41.00. Only the guard came.. no hardware. I have a 06 BX24... The holes were already in the frame. I just bought 4, 3/8''X 1" bolts, lock washers and nuts and it bolted right in place. Gives better protection than nothing. Works for me !:eek:
   / Kubota has upgraded HST Fan Protection #30
That is a good part of the reason that I went from a BX to a B, but I would still feel better with the new guard than with the set up that I had on my BX22. On the other hand, and specifications aside, my B doesn't feel like the go cart the BX did without the loader, etc. attached, and I'm not sure I will ever finish mow with it, and I would with a BX for sure. I would own one again now if Kubota, or someone came up with a decent material collections system for it. I loved the hydrostatic power steering when I was plug aerating, dethatching, etc.
2013 Ford Taurus SEL Sedan (A56859)
2013 Ford Taurus...
INOP Four Wheeler (A57453)
INOP Four Wheeler...
2015 GMC Yukon XL SUV (A56859)
2015 GMC Yukon XL...
Electric Horseless Carriage (A57453)
Electric Horseless...
PALLET OF 15 4 X 8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4 X 8...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
