Kubota L35 Third Function Valve Install
   / Kubota L35 Third Function Valve Install #31
Fantastic! Now I can get that Tee for my install. ;-)
   / Kubota L35 Third Function Valve Install #32
I just followed this procedure and installed the same third function kit on an L35 and ran into the exact same issue. I used the diagrams from this thread and quickly realized at the end that his pressure and return ports are incorrectly labeled on OP's diagram. I suspect that at the very end of things that he switched the hoses to fix the issue, but if someone were to follow the diagrams he used it wouldn't be correct.
Here's the actual layout of the loader valve so nobody makes the same mistake:
That is the return line. Goes to a Tee in the return line of the FEL.
This is the layout I have.
   / Kubota L35 Third Function Valve Install #33
Looking back at his pics, he definitely had the drain hooked to the pressure port. There's no way that just replacing a hose fixed his issue.
   / Kubota L35 Third Function Valve Install #34
LT1Pat,
I am getting ready to add a 3rd function valve to my L35. Did your valve function properly when you switched the pressure and return ports?
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
JOHN DEERE 850K LGP (A58214)
JOHN DEERE 850K...
2022 John Deere 5055E (A60462)
2022 John Deere...
16ft x 8ft Flat Bed (A57454)
16ft x 8ft Flat...
John Deere StarFire 6000 (A59814)
John Deere...
2016 Ford F-550 Venturo HT40KXX 3 Ton Crane Mechanics Truck (A59230)
2016 Ford F-550...
