Kubota rear remotes
   / Kubota rear remotes #1
BlacknTan
Platinum Member
Adirondacks of NY
Kubota B-7800
Does anyone have info on the Kubota kits for rear remote installation for a B-7800 or similarly sized tractor? Has anyone done this installation using the Kubota parts? Does anyone have pics?
A fella on the NH forum did an outstanding job of documenting the installation of three sets of remotes using NH parts on his CUT. The installation was clean and very slick. I'm looking for something similar from Kubota..........
Thanks, PS.
That certainly is a slick installation, and If I don't go the factory way, I'll definitely use your setup. I'd like to see the Kubota install first though......
You did a GREAT job on that setup. I'm very impressed!
   / Kubota rear remotes #4
The factory remotes for the Kubota B7800/B2710/B2910 are fairly expensive considering what you get. A comparible Prince SV setup will be less than half the price including hases and fittings. Since there is no rear hydraulic block on the B7800 your hoses will need to be a little longer.
Installation is easy and I have described it here many times before. If you do a search from about 3 years ago I documented how I installed mine. You can find it HERE.
You have a nice setup also Mad.
It appears that you and PS used different quick-connects than what I have on my loader. Why didn't you guys use the same type as on my factory loader?
   / Kubota rear remotes #6
What makes you think they are different? If you read my installation post you would have seen that I have 2 of the spools using 1/4" QD's and the other one a 3/8" QD. In my case the 1/4" ones are being used for a TNT since 1/4" allows better feathering. The 3/8" one is used for my dump wagon and any other standard hydraulic implements I may get a hold of.
Bear with me Mad. I'm a hydraulic neophyte!
What are the fittings you used called, if you don't mind my asking??
Am I correct in assuming that the QD'd you used and the ones Ps used are different??
   / Kubota rear remotes #8
You mean the QD's on the remotes? As long as the hose end male QD and female QD ends are compatible it makes no difference what brand you use.
Thanks PS.
I like the appearance of your setup much better!
24ft Corral Panel w/ 12ft Gate (A47809)
24ft Corral Panel...
WATER TANK (A47001)
WATER TANK (A47001)
New Veregro Blade Trailer With Arrow board (A45336)
New Veregro Blade...
Utility Trailer (A45336)
Utility Trailer...
2003 SHALE PRODUCTIONS SAND SEPARATOR (A47001)
2003 SHALE...
2018 RoGator 1100C (A46884)
2018 RoGator 1100C...
