L5030 Cat I/II hitch
   / L5030 Cat I/II hitch #1
slowzuki
Elite Member
New Brunswick, Canada
Kubota L5030 HSTC, MF 5455, Kubota M120, Allis Chalmers 7010
All you L5030 owners, could the components from your 3 point hitch be attached to a 4630/4330/3830 to provide a Cat I/II hitch? I'm guessing at the tranny break the smaller 3130 and 3430 won't accept the components.
I have access to many cat II implements that I would like to take advantage of.
   / L5030 Cat I/II hitch #2
slowzuki, according to the owners manual, which includes models L3130 thru L5030 only the L5030 has both category 1 & 2 three point hitch. To change from a category 1 to 2 on my L5030 I must remove a collar in the three point hitch where the pin inserts.
L3130, L3430, L3830, L4330, have category 1 only.
If you are suggesting using the L5030 three point hitch on another smaller tractor....I don't know... but there is probably a weight issue.
TxDon, I had a chance to look at a 5030 next to a 3830 on the weekend.
The arms and mounts appear to be identical on both except the 5030 seems to have lower arms with a 5 mm deeper profile. The extenders appear to be 5 mm deeper too.
My thought is with a little machine work I could use the extenders from the 5030 on a smaller one.
One could buy the 5030 lower arms and swap but that would be $$$.
The reason is the neighbours have some stuff set up for Cat 2 that isn't heavy and I would like to borrow.
Ken
   / L5030 Cat I/II hitch #4
If you are willing to do machine work, there are balls that have both holes. You could replace the Cat. 1 balls with Cat. 1 / 2 balls.
Mmm, I don't think I can forge something as big as a lift end to get the new ball to stay in!
I could get a pair of weld on ones with the 2 hole sizes!
The equipment I would be borrowing is a mix of I/II connections, the owners just slap the Cat II hitch on the cat I pins and go! I don't know if thats the best idea either.
   / L5030 Cat I/II hitch #6
you can get sleeves for converting CatI to CatII - otherwise you end up with knarly egg shaped hitch holes /forums/images/graemlins/crazy.gif
Yup I know, but the farmer neighbour has never used em.
I started looking at the stuff and realized most stuff he had was Cat 1 even though his tractors were all Cat 2. I think I should just change the pins on the the rest of his equipment!
3 bottom plow Cat 1 only
Tooth harrow Cat 1 / 2 combo
Woodsplitter Cat 1
Fertilizer spinner Cat 1
Bushhog Cat 1/2 combo
Tedder A Cat 1
Fencing spooler, Cat 1
Tedder B Cat 2
Rake cat 2
2021 New Holland C327 Compact Track Loader (A55218)
2021 New Holland...
2008 UTILITY VS2DX DRY VAN TRAILER (A54607)
2008 UTILITY VS2DX...
2013 Great Dane 53ft T/A Reefer Trailer (A51694)
2013 Great Dane...
2015 Ford Transit 250 Cargo Van (A55788)
2015 Ford Transit...
2017 KENWORTH T680 SLEEPER TRUCK (A54313)
2017 KENWORTH T680...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A54757)
UNUSED WOLVERINE...
