L5030 Cat I/II hitch
   / L5030 Cat I/II hitch #1
slowzuki
Elite Member
New Brunswick, Canada
Kubota L5030 HSTC, MF 5455, Kubota M120, Allis Chalmers 7010
All you L5030 owners, could the components from your 3 point hitch be attached to a 4630/4330/3830 to provide a Cat I/II hitch? I'm guessing at the tranny break the smaller 3130 and 3430 won't accept the components.
I have access to many cat II implements that I would like to take advantage of.
   / L5030 Cat I/II hitch #2
slowzuki, according to the owners manual, which includes models L3130 thru L5030 only the L5030 has both category 1 & 2 three point hitch. To change from a category 1 to 2 on my L5030 I must remove a collar in the three point hitch where the pin inserts.
L3130, L3430, L3830, L4330, have category 1 only.
If you are suggesting using the L5030 three point hitch on another smaller tractor....I don't know... but there is probably a weight issue.
TxDon, I had a chance to look at a 5030 next to a 3830 on the weekend.
The arms and mounts appear to be identical on both except the 5030 seems to have lower arms with a 5 mm deeper profile. The extenders appear to be 5 mm deeper too.
My thought is with a little machine work I could use the extenders from the 5030 on a smaller one.
One could buy the 5030 lower arms and swap but that would be $$$.
The reason is the neighbours have some stuff set up for Cat 2 that isn't heavy and I would like to borrow.
Ken
   / L5030 Cat I/II hitch #4
If you are willing to do machine work, there are balls that have both holes. You could replace the Cat. 1 balls with Cat. 1 / 2 balls.
Mmm, I don't think I can forge something as big as a lift end to get the new ball to stay in!
I could get a pair of weld on ones with the 2 hole sizes!
The equipment I would be borrowing is a mix of I/II connections, the owners just slap the Cat II hitch on the cat I pins and go! I don't know if thats the best idea either.
   / L5030 Cat I/II hitch #6
you can get sleeves for converting CatI to CatII - otherwise you end up with knarly egg shaped hitch holes /forums/images/graemlins/crazy.gif
Yup I know, but the farmer neighbour has never used em.
I started looking at the stuff and realized most stuff he had was Cat 1 even though his tractors were all Cat 2. I think I should just change the pins on the the rest of his equipment!
3 bottom plow Cat 1 only
Tooth harrow Cat 1 / 2 combo
Woodsplitter Cat 1
Fertilizer spinner Cat 1
Bushhog Cat 1/2 combo
Tedder A Cat 1
Fencing spooler, Cat 1
Tedder B Cat 2
Rake cat 2
Ford 655C 2WD Cab Backhoe (A55301)
Ford 655C 2WD Cab...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
2023 54' Hooklift Dumpster 15 Cubic Yard (A55788)
2023 54' Hooklift...
UNUSED LANDHONOR AD-12-23C HYD AUGER (A54757)
UNUSED LANDHONOR...
UNUSED SDLANCH SDLGC ELECTRIC GOLFCART (A54756)
UNUSED SDLANCH...
