Land plane questions
   / Land plane questions
good explanation, Woodland..... I think I will stick with the original plan of getting the drag land plane. I now have a better understanding.
   / Land plane questions #22
I have seen a land plane with both a 3-point and a skidsteer mounts on it.
If you know a welder, some framework/SS plate could be put on the back to facilitate pushing, and then you could pull. It would add some stiffness and some weight.
   / Land plane questions #23
I'd go with a 3pt & then add a SSQA mount to the back down the road if you felt it was worth it. SSQA plate is $150 maybe $200 for a beefier one delivered. A local welder could easily Fab up some mounting struts for it for a couple hundred if you can't weld & fab. Wouldnt affect the 3pt aspect at all.
   / Land plane questions #24
That's certainly what I was getting at.
Or, do a ssqa to 3 point quick hitch. The skid steer can drive backwards and do it. Maybe $200 for the adapter. Xaf has one.
   / Land plane questions #25
I made one. Welded a quick hitch to a SSQA plate. Pushing $400 in raw materials if you buy new. They were over &1k for a prefab one. Although I think Titan or somebody started making a cheap one in the past year or so.
Talked to the guy selling the Terraplane, and apparently it has fixed blades that are non-adustable. He tells me the plane is set at a 2" cut and you just raise or lower the 3 pt hitch to vary the depth. I would think that if the plane wasn't riding on flat on the surface of the driveway (because I wanted a shallower than 2" cut- due to my ground up asphalt driveway), I would run into the same issues I would be having with my box scraper making washboards, rather than curing them. Told him I was possibly going to take a look at it tomorrow, but it is a 50 mile drive for me, so I would like to know ahead of time if I should bother going to see it. Does it make a difference?
   / Land plane questions #27
I would not be happy with a fixed depth. Mine is set as shallow as it goes. 2" would make a mess in my sand.
Of course, ymmv.
Good luck.
   / Land plane questions #28
Of course, ymmv.
Good luck.
Yep, fixed blades would suck. I made mine adjustable. 0 to about 2".
   / Land plane questions #29
I have to respectfully disagree. Adjustment capability is good though. In most cases when pulling with a tractors and having roads with minimal surface thickness 2" is way to much.
I wonder how often you adjust your blade height ? Or did you just find a height you liked and left it there ??
gg
   / Land plane questions #30
gg
I agree that height adjustment is not very important but fixed at 2" is not acceptable. Anywhere from 0 to 3/4" fixed should work okay.
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
2012 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A59904)
2012 FREIGHTLINER...
John Deere 5105M (A53317)
John Deere 5105M...
iDrive TDS-2010H...
Bobcat MT85 (A60462)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
