Log Bench
/ Log Bench #13
Here is a simple one I made from a cut off from our mantle. Its all hemlock.
/ Log Bench
Thank you I am learning:confused3:
/ Log Bench #16
When I built my cabin almost 20 years ago I made a half dozen benches for visitors and scattered them around the trails. I found some dead-fall oaks about 20 inches in diameter and cut them into about five foot lengths. I sliced those in half with the chainsaw and used the saw to cut a "V" about 6 inches from each end on the rounded or bark side. I then went back to the log and cut some 24 inch logs and cut a bit off one side to make it flat, then arranged them so the flattened half log lay across them. It made a sturdy bench and they lasted about 10 years. I then made more the same way. Easy and effective way to get seating... And it looks good in a forest setting.
I cut some which sound similar just to use them around our trails and fire pit.
2012 DRAGON 130BBL VAC TRAILER (A60736)
2012 DRAGON 130BBL...
2012 Kubota ZG222 (A60463)
2012 Kubota ZG222...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A61307)
Case Wheels for...
2010 Deere 318D (A60462)
2010 Deere 318D...
2021 CATERPILLAR D3 CRAWLER DOZER (A62129)
2021 CATERPILLAR...
2021 VERMEER S925TX STAND ON SKIDSTEER (A52709)
2021 VERMEER...
