Looking for 85 hp tractor
   / Looking for 85 hp tractor #21
Nice... ( druel hitting keyboard... )
Soundguy
   / Looking for 85 hp tractor #22
Dumb question? Do you really think you need a 85 hp. tractor to mow and plow snow with? Must be one **** of a pasture>
   / Looking for 85 hp tractor #23
What's wrong with wanting an 85hp tractor to mow with?
I mow with a ~95 hp tractor.... Only got 13 ac.. but i like to get it finished in 2hrs or less... hard to do that with a small tractor and small mower...
Soundguy
   / Looking for 85 hp tractor #24
I personally think it is a bit of an over-kill. I would equate this to hunting rabbits with a Sherman tank.
   / Looking for 85 hp tractor #25
Soundguy
We sometimes have a 140 HP tractor on a 10' mower.
Overkill = probably. But it gives a real smooth ride for the driver, you can go really fast (12MPH +) and it is the only tractor availible sometimes.
I don't see anything wrong with wanting a big tractor.
You normally get more tractor for your money when you go bigger secondhand too.
   / Looking for 85 hp tractor #26
Over kill would be putting an 85 horse tractor on a 6 foot finish mower and mowing your lot in town. Of course I know an old farmer who does this for his yard which is not much bigger :)
   / Looking for 85 hp tractor #27
Or buying a 7710 for a 2.3 acre lot as a back up when you already have a JD2555 as the primary mower... unless you count the Steiner???
Some of us just like more hp rather than more time!
David from jax
   / Looking for 85 hp tractor #28
David, weren't you planning on starting a business with your 7710?
Personally, if you can write the check then buy what you want. Who cares if someone thinks it is over kill. They don't know what the owners intentions or future plans are. In this case, no one knows the OP's property size or location. He could be mowing 100 acres of pasture or 5 acres. And I don't consider 85 horsepower tractors to be big:rolleyes:
   / Looking for 85 hp tractor #29
vem said:
I need approximately 85 hp tractor for plowing snow and mowing pastures. Of course must have loader, 4wd, and a cab.
Not sure why you need a 4WD? Have you ever driven a 2WD 85HP tractor? Unless you are driving through some thick mud, you would have a hard time getting one stuck.
I can't see how mowing and snow plowing would require 4WD.
   / Looking for 85 hp tractor #30
I've seen them get stuck. And they are difficult to rescues when they do get stuck.
Four wheel drive is usefull if you are mowing on a steep slope. It gives you better traction and steering going across, and helps with scuffing if you are going up and down the hill. But it does reduce the turning radius.
For plowing snow, it probably wont really do much, except to help steer alot.
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
JOHN DEERE 644K WHEEL LOADER (A58214)
JOHN DEERE 644K...
John Deere 853 20ft Corn Head (A56436)
John Deere 853...
(APPROX. 25) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 25) 4' X...
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
12ft 9in Altec Service Bed (A57453)
12ft 9in Altec...
