Looking for a source for Lowes (Task Force) parts
   / Looking for a source for Lowes (Task Force) parts #1
stuckmotor
Super Member
Lower Up State S.C.
AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs
The height adjustment knob on my 10" bench table type saw is about to bite the dust. Does anyone know if there is a parts supplier for Task Force equipment?
   / Looking for a source for Lowes (Task Force) parts #2
Have you tried asking Lowes for a parts source?
   / Looking for a source for Lowes (Task Force) parts #3
I buy a fair amount of knobs to restore old tools. Once you know the size of whatever the knob attaches to and whether or not it has threads, it is pretty straightforward.
McMaster-Carr stocks lots of knobs;
https://McMaster.com
Don't forget E-Bay as well.
All the best,
Peter
Thanks Peter,
I probably should have called it a wheel instead of a knob. It has teeth on the bottom for adjusting tilt and grooves in the top for adjusting height. I'm pretty sure it's specific to this saw and I didn't see if at McMaster Carr or ebay. If it doesn't turn up on ebay and Lowes can't help. I think I can make something like the hand crank on an old AC tractor as a workaround.
   / Looking for a source for Lowes (Task Force) parts #6
Thanks Peter,
Yes, that does sound pretty specific, and critical, to your saw. Model #? Photo? I am having trouble visualizing it.
LG sourcing made them for Lowes, but to be honest I am not seeing machine specific parts, and they seem to have moved on from the brand in power tools.
All the best,
Peter
Peter
The first photo shows the blade height adjustment. To raise the blade a spring pushes the wheeI' back so that the roll pin catches between the little bumps around the shaft and spins a threaded rod that raises the blade. The bumps have worn down or broken off and now I can just pull the wheel back enough to make it work. I might rebuild the bumps with some liquid steel type product but think building a crank to fit over the roll pin would be more of a sure thing.
Peter,.
The additional photos are only because you seemed interested in the mechanism. The model number could be hidden under the homemade legs. The wooden "knob" on the wheel works fine, the center hole is probably too big because I was in a hurry and used whatever bit was handy.
   / Looking for a source for Lowes (Task Force) parts #9
   / Looking for a source for Lowes (Task Force) parts #10
Peter,.
Thanks! That really helped. I was having trouble visualizing the dual functions of your knob, but I understand it now.
I can't find a parts source for it, sorry. Your idea of liquid steel seems like a good interim fix. If you are really attached to that saw, our could consider finding a knob that you can cut a slot in for the pin, and source a gear that you can weld/pin to your knob. Alternatively, you could drill out the existing pin engaging lobes and press in a new steel part with lobes or slots to match the pin. (Like half a Lovejoy coupling)
Good luck!
All the best,
Peter
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2001 INTERNATIONAL 4900 WATER TRUCK (A58214)
2001 INTERNATIONAL...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
FUEL CELL (A58214)
FUEL CELL (A58214)
CAT Chassis Only (A59076)
CAT Chassis Only...
