Looking for info on how to pour a slab
   / Looking for info on how to pour a slab #41
I make up a couple of bull floats. A piece of 2x6 about 32" long attached to a 2x4 with the handle end ripped down so that you can grab it routed round lol. the handle is at 27 degrees to the floor. I haven't go time to do a full dwg but here is a side view.
Sorry here is the image of Bull Float
Egon ya loose loamy soil, lol.
   / Looking for info on how to pour a slab #42
Your city's/county's building codes will tell you how big your footing need to be. Rebar is always good in the footings for added support. Back fill with sand as needed and pack it. Cover the sand with a thick plastic as a moisture barrier, use foundation wire on top of the plastic. With a pad that big you need to use joint expanders. This is used to control the cracking of your slab. Cracking is good BUT these will control where the cracking occurs.
For pumbing or electrical coming though the slab, you'll need to dig your trenches, lay pipe, etc. before you do any prep work. This is not an all inclusive list but enough to get you going. There are two ways to pour a slab; footings THEN the slab or pour the footings and slab all at once. Both have advantages! Good luck and congrats on staying debt free!!! :thumbsup:
Bull float... [ame="http://www.youtube.com/watch?v=6RS6425XuXA"]http://www.youtube.com/watch?v=6RS6425XuXA[/ame]
You'll need to rent a trialing machine for a big slab.
Bull float will smooth out the slab after you pour it. After you bull float it and you can just barely walk on it... time to use the trialing machine. Visit youtube and you can see a bull float and trialing machine in action!
POLY TRASH TILT DUMPER & 44" SHOP FAN (A57192)
POLY TRASH TILT...
18" PIN ON BUCKET (A52707)
18" PIN ON BUCKET...
TANK MANIFOLD (A58214)
2013 Ford Explorer AWD SUV (A55853)
2013 Ford Explorer...
WOODS TBW144 TURF BATWING ROTARY MOWER (A57192)
WOODS TBW144 TURF...
UNUSED PABREAK BC352 - 72" HYD BRUSH CUTTER (A57193)
UNUSED PABREAK...
