metal piece came out of oil pan when changing oil
   / metal piece came out of oil pan when changing oil
What do you think this is or actually was.
   / metal piece came out of oil pan when changing oil #32
I am not at all familiar with that part. A mechanic that specialises in the model would tell you. It may not be the first time it has happened to those motors either. Could be an oil anti slosh damper but it still shouldn't have broken like that. It certainly dosen't look like any major engine component anyway.
Hello ,I will probably check with the local case dealership , they still deal parts for the 35 .I can probably get a schematic or actual part number for it . looks like it shouldn't be there at all but it had to come from above. The timing gear is open to fall into the pan as well ,so it might have fallen off from that . IT might be an oiler mechanism .At LEAST it wasn't to hard to take off the oil pan .Glad I did.
   / metal piece came out of oil pan when changing oil #34
Got the oil pan . this is what was in it. the rest of the pieces.
That looks like it would have been part of the oil pan itself...........if I'm not mistaken.
   / metal piece came out of oil pan when changing oil #35
That's sure an odd place for a screwdriver holder rack.
   / metal piece came out of oil pan when changing oil #36
It is, or I should say was, part of the governor assembly, the shape is unmistakable. You will need to remove the timing cover to inspect it. See the images below, where I've included your image for comparison.
I strongly advise that you purchase a shop manual, if you don't already have one. In the mean time, the following diagram should help you understand where various parts are located.
   / metal piece came out of oil pan when changing oil #37
By golly, we may have a winner :thumbsup:
Thanks , I will get a manual , and again thanks for sending those diagrams and advice.
Thanks Massey WV , Iguess that part is wore out , those images are very helpful much appreciated.
   / metal piece came out of oil pan when changing oil #40
yep.. deffinately looks like it could have held some flyballs...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATES (A54757)
UNUSED LANDHONOR...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A55301)
2012 UNVERFERTH...
2000 Freightliner FL70 Manitex 14 Ton Crane Truck (A55788)
2000 Freightliner...
2016 NISSAN VERSA Sedan (A53424)
2016 NISSAN VERSA...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55301)
NEW HOLLAND 706 30...
