metal piece came out of oil pan when changing oil
   / metal piece came out of oil pan when changing oil
What do you think this is or actually was.
   / metal piece came out of oil pan when changing oil #32
I am not at all familiar with that part. A mechanic that specialises in the model would tell you. It may not be the first time it has happened to those motors either. Could be an oil anti slosh damper but it still shouldn't have broken like that. It certainly dosen't look like any major engine component anyway.
Hello ,I will probably check with the local case dealership , they still deal parts for the 35 .I can probably get a schematic or actual part number for it . looks like it shouldn't be there at all but it had to come from above. The timing gear is open to fall into the pan as well ,so it might have fallen off from that . IT might be an oiler mechanism .At LEAST it wasn't to hard to take off the oil pan .Glad I did.
   / metal piece came out of oil pan when changing oil #34
Got the oil pan . this is what was in it. the rest of the pieces.
That looks like it would have been part of the oil pan itself...........if I'm not mistaken.
   / metal piece came out of oil pan when changing oil #35
That's sure an odd place for a screwdriver holder rack.
   / metal piece came out of oil pan when changing oil #36
It is, or I should say was, part of the governor assembly, the shape is unmistakable. You will need to remove the timing cover to inspect it. See the images below, where I've included your image for comparison.
I strongly advise that you purchase a shop manual, if you don't already have one. In the mean time, the following diagram should help you understand where various parts are located.
   / metal piece came out of oil pan when changing oil #37
By golly, we may have a winner :thumbsup:
Thanks , I will get a manual , and again thanks for sending those diagrams and advice.
Thanks Massey WV , Iguess that part is wore out , those images are very helpful much appreciated.
   / metal piece came out of oil pan when changing oil #40
yep.. deffinately looks like it could have held some flyballs...
2021 TAKEUCHI TB235-2 EXCAVATOR (A52706)
2021 TAKEUCHI...
2016 Kubota SVL 75-2 (A47477)
2016 Kubota SVL...
(APPROX 15) 2" X 6" X 68" TUBING (A54756)
(APPROX 15) 2" X...
2012 Ford F550 Service Truck (A52377)
2012 Ford F550...
JOHN DEERE 5075E LOT NUMBER 30 (A53084)
JOHN DEERE 5075E...
96" X 53' FLATBED TRAILER (A52706)
96" X 53' FLATBED...
