MF65 "Multipower" does not work.
   / MF65 "Multipower" does not work. #11
How did you get on with the Multipower unit. I have a MF148 which is only operating in low. Is there anything I can look at or check before I start to pull it apart. Someone suggested I weld it up but I want to retain the multipower features and the higher operating speeds in "high"
   / MF65 "Multipower" does not work. #12
pretty sure there is a soft line in the the hydraulic section the runs from a pump to the transmission to a clutch or something like that, it could be broken i had a 165 with multipower I wouldnt buy one again. also check the linkage and if oil is coming out of the weep hole on the bottom of the bell housing.
   / MF65 "Multipower" does not work. #13
I had a mf 165 with multi-power that was stuck in low, no engine braking. Tractor needed to be split to repair. I traded it in for my jd990.
   / MF65 "Multipower" does not work. #14
I believe you have to have high pressure oil flow for the "hi-power" selection to work. There is an additional oil pump in the transmission section (just behind the bell housing) that supplies the needed oil and pressure. There is a bulkhead fitting on the clutch side of the bell housing with a metal tube attached. The other end is connected to the oil control valve which is part of the input shaft bearing housing. There are a few things you can check because it sounds like you may not be producing oil pressure or dumping oil in the bell housing. You will have to split the tractor. Once split, loosen the nuts and remove the oil tubing. Next, make sure the tractor is in neutral as well as the PTO. Rotate both input shafts, in the proper direction, to see if any oil is pumped by the secondary oil pump. If not, consider rebuilding or replacing the secondary pump. Another thing to check is the "o-ring" on the oil control valve spool. A 10 cent piece of rubber will shut you down, if worn or damaged. The next text is to take a air blow off nozzle with a rubber cone tip and stick the rubber cone into the oil inlet fitting on the oil control valve. Apply air pressure in both multi-high power and low settings to see if any air escapes around and through both input shafts. If so, the snap rings will have to be replaced on the other side of the bell housing.
   / MF65 "Multipower" does not work. #15
Thanks everyone for the info. Looks like we will have to split the tractor to get it to work properly.
   / MF65 "Multipower" does not work. #16
Before I split this tractor (MF148) and repair the multipower can anyone tell me if a standard 6 speed or 8 speed box will bolt straight into this tractor without major modifications. I am just looking at my options at this point. Vince
   / MF65 "Multipower" does not work. #17
G'day yes you can bolt a standard 6 speed box straight up to it or you can weld the multi power up and put it back that way
Jon
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
VOLVO EC460CL EXCAVATOR (A58214)
VOLVO EC460CL...
2012 DRAGON 130BBL VAC TRAILER (A58214)
2012 DRAGON 130BBL...
Brock 60'x26' Flat Bottom Grain Storage Tank (A57148)
Brock 60'x26' Flat...
light tower (A56857)
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
