Mini-ex in steep terrain?
   / Mini-ex in steep terrain? #1
sea2summit
Super Member
Left coast of, GA
Kubota 1860->25D, MX5800, M4D
Moved to some new property in GA and about 10 acres of the property is choked up with what we call around here "wait a minute vines" which is basically a nice way to say you ain't getting through there. I was thinking about getting a little tiny mini excavator and clearing some of the vines and doing some selected removal of a lot of the small pine trees that appear to be working on growing among the more desirable species. Only problem is the terrain is steep drainage and I know I can't get some of it but a lot of what I'm thinking about attacking is 10-15% grade. Could a mini-ex safely operate in there without having to tear up the ground too much building working pads etc? Specifically I'm looking at renting a Kubota k-008 or kx-18 size mini-ex.
   / Mini-ex in steep terrain? #2
Is the soil typical GA clay? 15% ~30-degrees is a decent slope; I'm not sure rubber tracks can hold, but a smaller ex with metal tracks could do it.
   / Mini-ex in steep terrain? #3
You should be able to negotiate a 15% grade with your tractor. If it has a loader and you have a bush hog type mower I would attack the vines and small trees with that first. A mini EX is more tipsy than a tractor IMO. Great care and remembering to keep the grader blade low would be needed on any decent slope.
If you are talking a 15 degree slope that is a different animal but should be able to approach in forward or reverse.
   / Mini-ex in steep terrain? #4
If I am working on a steep slope, I build a level pad up under the excavator. Get to where you want to work, work bottom up, and then dig a hole next to the machine and make a pad. Then drive over onto the pad. It will take a zig saw pattern to get to the top of the hill, but it's definitely doable.
Mostly sand here, clay starts for me about 18" down.
Lots of stuff I wouldn't be able to safely side hill or turn on and lots of tight spaces between trees so that's why I was thinking a mini-ex might be a better choice. Tractor may get enlisted for some of it though.
   / Mini-ex in steep terrain? #7
As a proud new owner of a Yanmar O35 mini-ex, I have to say that they are the bomb for ripping out vines. I have Himalayan blackberry on portions of my property and I hate, hate, hate them. I've attacked them with Crossbow and with a brush trimmer on more occasions than I care to remember over the years. The excavator is the perfect tool for ripping them out and piling the vines for burning. I love it.
15% is only 8 degrees and should be easily negotiable by the excavator as long as you keep the tracks perpendicular to the slope. Even 15 degrees should be doable, just don't go along the side slope unless you have the bucket pointed downhill for additional support if you should need it.
   / Mini-ex in steep terrain? #8
Perpendicular??? I attack my steep terrain straight on with the blade downhill so I can use it to lift up and level me off and to dig in. Just be EXTREMELY careful when swinging a full bucket, lots of inertia there...
   / Mini-ex in steep terrain? #9
Yes, tracks pointed downslope is perpendicular to the slope. Parallel would be tracking along the slope at the same elevation.
   / Mini-ex in steep terrain? #10
Beat me to it. :thumbsup:
Just "scratching" vines with little to no weight you can relax about swinging over the side. 15% OR 15* is still an easy slope to operate on, but being "new" to a rental machine and not sure of it's limits, start out slow.
   / Mini-ex in steep terrain? #11
I have put about 1000 hrs on a k-008. They are tipsey side to side but pretty stable forward/backward if you keep the counter weight up hill. You can actually side hill pretty well if you swing the turrent to where the counter weight is uphill.
I made a shoe for my bucket with a 2 1/2 foot long piece of road grader blade for backfilling and cleaning up. It will cut vines/small brush/weeds surprisingly well. Backfilling is at least 2 or 3 times as fast with the add on blade plus you can leave the rake in the truck.
The tracks are small and the will tear up yards pretty fast if you have to turn much.
   / Mini-ex in steep terrain? #12
Snobdds,
Can you describe this method a little more for me?
I've got a 30 degree slope that I want to build into about 4 level tiers.
Park at the bottom. Dig a hole next to me and fill above me on the slope to make a pad? Then drive up onto that pad?
   / Mini-ex in steep terrain? #13
Snobdds,
I believe he's describing basic "cut & fill". You don't actually dig a hole, just cut down the high side enough so that what you remove (and placed on the low side) creates a level "pad" similar to how you'd cut in a road or trail across a slope. For example cut 10" up hill and fill 10" down hill.
That's what I'm understanding. I don't want to do that if I can avoid it for erosion issues and trying to save as much habitat as possible for this deer season.
V.E. ENTERPRISES 500 BBL FRAC TANK (A58214)
V.E. ENTERPRISES...
CATERPILLAR TL642C TELESCOPIC FORKLIFT (A60429)
CATERPILLAR TL642C...
2019 KOMATSU D61PXI-24 CRAWLER DOZER (A60429)
2019 KOMATSU...
iDrive TDS-2010H...
2005 John Deere 7420 (A60462)
2005 John Deere...
Leyman Lift Gate (A59230)
Leyman Lift Gate...
