motorhome convert to pickup
   / motorhome convert to pickup
   / motorhome convert to pickup #23
If you wanted a little fancer look see if the van cab is the same as the van, (my guess it is), and find a old van and cut off the back for the rear of the cab, and then put a flat bed or small dump box on it,
   / motorhome convert to pickup #24
This would work and probably be easier .
I would just go with a used flatbed .
   / motorhome convert to pickup #25
Her is a picture of the door tag on the Chevy 3500. There was another tag, but somebody painted over it.
.... now the smoke has cleared (i was thinking)
obviously I was not thinking about gas mileage... or lack of gas mileage!
   / motorhome convert to pickup #27
Steve, you probably know that the welded-on frame extension in a Class C motor home of that length with that Chevy chassis is intended only to support the back end of the coach and a light-duty Class III hitch. Structurally, it will be a major weak point of your conversion if you leave the extended frame intact. I wouldn't plan on being able to do much bumper-pull towing. What is the current tow rating on the MH? I'm betting it is only 3500 lbs, with maybe a 350 lb tongue weight. You won't be able to increase that very much. Your idea of adding a fifth-wheel hitch is interesting. BTW, I hope this will be a labor of love if you undertake it, because it sounds like a lifetime project. :)
yeah your right threepoint.. I cant do as pictured above. because I will be towing / hauling on a regular basis. I just hope they didn't butcher the frame too much. I am hoping they just drilled new holes and used studs to relocate the hangers. and then I hope they just bolted and not welded a extention onto the back that I can just take off.
   / motorhome convert to pickup #30
my guess is the van frame is different from the pickup frame, I suggest keep the van cab and close of the back of it, (my 78 ford van and pickup frames are different, that much I do know) I do not know if there close enough to set the pickup body on and then reconfigure the steering and clutch and brake set up, and the transmission shifters,
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
Xtreme Power MIG 195 (A57454)
Xtreme Power MIG...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A56859)
2014 Glasstream...
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
Echo SRM-266T Weedeater (A57453)
Echo SRM-266T...
