Mow septic field or not
   / Mow septic field or not #21
I hadn't considered this issue; I'll admit I've actually been using mine as a food plot. Plow it (the leaching field pipes are over 2 feet deep) and plant annual crops 2X year. Maybe just lucky so far, as no issues in the four years I've had it.
   / Mow septic field or not #22
Mow it. That pipe is a lot harder to crush than most people think. I suspect what your installer was meaning was keep heavy mowers off of it until everything had time to settle. As someone here already mentioned, clay packs itself over a short period of time. Mow it and dont worry about it.
   / Mow septic field or not #23
Compacting the soil OVER the leach field shouldn't be a problem. You don't want to compact the gravel under or around the pipes, nor break or bend the pipes.
Personally, I stay off my leach field with my CT230; and mow it with a push mower.
   / Mow septic field or not #24
We have run over ours with everything from the kids bikes to the L3830 pulling a baler and a wagon load of hay... Not a whole lot of choice due to its location (right in the only path from the hayfield to the barn).
Aaron Z
Roll of 2-inch Vacuum Hose (A57454)
Roll of 2-inch...
*Selling at Royal Auction Tampa, FL Location* (A59230)
*Selling at Royal...
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
2014 Chevrolet Impala Sedan (A59231)
2014 Chevrolet...
2020 Utility FS2CDHE 45ft. 35 Ton T/A Drop Deck Flatbed Trailer (A60460)
2020 Utility...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
