Mow septic field or not
   / Mow septic field or not #21
I hadn't considered this issue; I'll admit I've actually been using mine as a food plot. Plow it (the leaching field pipes are over 2 feet deep) and plant annual crops 2X year. Maybe just lucky so far, as no issues in the four years I've had it.
   / Mow septic field or not #22
Mow it. That pipe is a lot harder to crush than most people think. I suspect what your installer was meaning was keep heavy mowers off of it until everything had time to settle. As someone here already mentioned, clay packs itself over a short period of time. Mow it and dont worry about it.
   / Mow septic field or not #23
Compacting the soil OVER the leach field shouldn't be a problem. You don't want to compact the gravel under or around the pipes, nor break or bend the pipes.
Personally, I stay off my leach field with my CT230; and mow it with a push mower.
   / Mow septic field or not #24
We have run over ours with everything from the kids bikes to the L3830 pulling a baler and a wagon load of hay... Not a whole lot of choice due to its location (right in the only path from the hayfield to the barn).
Aaron Z
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Deere 310L (A53317)
Deere 310L (A53317)
2014 RAM 2500 (INOPERABLE) (A58214)
2014 RAM 2500...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
5th Wheel Hitch (A59230)
5th Wheel Hitch...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
