Mow with my bx24 or buy a zero turn mower?
   / Mow with my bx24 or buy a zero turn mower? #21
Something to consider is how much TIME you spend on various chores. Weekly/biweekly mowing can really add the hours of seat time, versus digging a hole for a tree, or hauling firewood in the FEL.
To each his own, but I view mowing as a mindless chore, one that needs to be done as quickly as possible. Using a machine designed for that task makes sense. I'd look for a good, used commercial ZTR from a dealer. It may no longer be up to working 40 hours a week, but it will still have many years left for a homeowner's yard.
   / Mow with my bx24 or buy a zero turn mower? #22
one other thing is if the tractor has a break down and takes awhile to get fixed...Grass grows pretty quick around here...Had the same situation you did and decided on the ZTR..Bad Boy.. No regrets..wife loves it and I get to ride on the tractor doing other things at the same time:laughing:
   / Mow with my bx24 or buy a zero turn mower? #24
I have owned both and initially thought a Zero turn was mostly hype. Man was I wrong. I had the 60" deck on a BX22 and it did all right. Some scalping at times but that depends on how truly flat all of you area is. The zero turn will do the area in easily 1/3 the time of the Bota with MMM deck. I own a Scag Freedom Z 52" and it works like a dream. Don't get caught in the trap of buying some of the Zero turn crap out there. Most of the commercial grade manufactures make an entry level machine that works well for home owners. Cub Cadet, Husqy, Toro via Home Depot/Lowes/Tractor Supply sell mostly the tinny crap. Scag, Ferris, Kubota, Snapper are solid well built machines. Stay with the Kawasaki engines and not the Briggs and Stratton, Tecumseh or Kohler. They will work but they are just not the same. If you value your time you will go with a quality made zero turn.
Excellent advice, every bit of it.
   / Mow with my bx24 or buy a zero turn mower? #25
Frankly, I have never mowed with either, but zipping around with that zero turn mower looks like a lot more fun!
   / Mow with my bx24 or buy a zero turn mower? #26
I have for years preferred one single engine to take care of, so I tried to buy as many PTO driven. e.g. rototiller, implements as possible. If I had the money now, I would trade and get a B series tractor and either a ZTR or F series mower. I do not have the money for that, however.
I have the 60" deck and a BX2200. This machine really does cut well. I had the blower/bagger but did not like it. Emptying the bags took a lot of time and getting the thing on and off was really difficult. The top link is fused to the frame of the bagger and does not pivot. There was a lot of pressure on the top link pin at the 3ph and it was hard to get out. It was also difficult to align the holes when putting it on. I finally sold it to another TBN member and put a mulch kit on the deck. This was a great improvement. No emptying bags, one unnecessary implement no longer taking up space, and the mulched clippings return the nutrients to the soil, eliminating the need to fertilize. The mulch kit was only $200, compared with the couple of thousand for the bagger. Going this route would lower your output for an MMM. You do need dry grass to mulch cut, however. The clippings need to be dry and light enough to float around in the baffles in order for them to really get the "vegematic" treatment. Otherwise you get thatch on the ground, which will kill the grass beneath by blocking sunlight. It never rains here in summer. I irrigate on Monday and Tuesday, then cut on Saturday or Sunday when the turf is dry; this way the mulch system works as designed. For those who live where it could rain at any time during the cutting season, wet grass can pose a problem.
I have a custom built dolly for my MMM and with a concrete slab can get the MMM off in 2 min. and on in 3 to 4. With the dolly, there's no need to rotate the anti-scalp wheels. I have worked on my technique and can usually get the mid-PTO shaft coupled in just 3 or 4 seconds. It's funny how many others were able to do the bagger frame so much faster than I could, but coupling the MMM to the PTO is the opposite.
A ZTR or F series really would cut faster than the BX with MMM though, as well as make sharp radius turns that the BX cannot do without rocking on the pedals, forward and backwards a couple of times. I like the F series better because of its higher speed and steering wheel. I am not crazy about those steering levers on ZTRs, but thats just my own personal preference. I guess if I used one long enough, I would eventually get the hang of it. The downside is that an F series is considerable bucks. I agree with all the others about going with a commercial manufacturer. It might be a greater up front investment, but there is something to be said for paying twice as much for something that will last 10 times as long.
Best of luck with your purchase and let us know how it all works out.
   / Mow with my bx24 or buy a zero turn mower? #27
I give another vote to the ZTR. I bought one a couple of years ago. It will mow circles around my tractor. It worked out even better than I thought because my wife took a fancy to it and now does most of the mowing. That gives me more tractor seat time as well as time for other things that were getting behind. I went with a 52in because I was concerned about scalping. I think the next one will be a 60in or larger as we get our yard smoother. I will also suggest springing for the suspension seat if your yard if rough at all. It cost me an extra $300 but after having it and operating others that don't, I would do it again without a thought.
   / Mow with my bx24 or buy a zero turn mower? #28
I would go with the ZTM also.
I bought the MMM with my BX2660 planning to sell the Cub Cadet hydro garden tractor that I have been mowing with. I mow a lot of sloped lawn.
No way can I mow with the Kubota near the top edge of steep banks or mow slopes that the Cub Cadet does. I mow with the Cub Cadet in places that would roll the Kubota. I feel now that the MMM was a waste of money because I dought I will ever hook up the MMM again.
   / Mow with my bx24 or buy a zero turn mower? #29
Another vote for ZTR here too. I have a 48" Scag Tiger Cub. I mow 3 acres of my own here and 3 yards in town that I mow also. To mow my yard it takes me a little over 3 hours, if my yard was all one piece it wouldn't take me that long, but you have to mow around the garden, the blueberrys, the trees...
I really need a 60" but thats a little further down the list. I'd like to try a Ferris those springs on the front look spiffy!
   / Mow with my bx24 or buy a zero turn mower? #30
So far, the consensus is the ZTR, if you had an acre or less I would have recommended the MMM for your Bota.
With 2 acres to mow............that changes the game. Get the biggest deck that will work on your lawn, and be sure to get a 'commercial' machine.
1025 (A48836)
1025 (A48836)
1989 Chevrolet Corvette Passenger Car, VIN # 1G1YY318XK5111655 (A48836)
1989 Chevrolet...
2013 Brent 882 (A47164)
2013 Brent 882...
LOT LOCATIONS (A45679)
2014 WESTERN STAR 4900 SA TANDEM AXLE DAY CAB (A50046)
2014 WESTERN STAR...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A48081)
2000 Thomas Built...
