My Garage/Shop Heater Install
   / My Garage/Shop Heater Install #221
Manual calls for 1/8" gap, should work at that or SLIGHTLY less - depending on how "robust" the spark transformer is, getting it TOO much less may shorten the life of the transformer (on the control board) ... Steve
The ground electrode is attached to the mounting plate, which typically isn't very thick - so when re-installing, be careful NOT to cause the plate to flex or it'll CHANGE your gap setting. Good luck...
   / My Garage/Shop Heater Install #222
Lets get going on this......:)
   / My Garage/Shop Heater Install #223
Mark, just remember the most accurate definition of troubleshooting - it's finding all the things it's NOT (or at least, until you get to the one that IS):rolleyes:
   / My Garage/Shop Heater Install #224
I want to see heat or a explosion ...............:laughing:
   / My Garage/Shop Heater Install #225
Yeah, either of those would verify the "fire triangle", the heat might be a bit less painful :laughing:
   / My Garage/Shop Heater Install #226
Ya , Were in 2 different time zones I don't want to have get up out of bed to a big boom......:laughing:
My day job has been getting in the way. I’ll report back in a couple hours.
   / My Garage/Shop Heater Install #228
10-4....
   / My Garage/Shop Heater Install #229
Who'd a thunk they actually meant WORK from home??!? Bastids... :confused: ...Steve
Had I known when I started this thread, I would have added the word 'Saga' to the title.
I monkeyed with the flame rod as suggested in the previously posted YouTube video on Reznor ignition problems. Bent the rod towards me 1/8in off from vertical and 1/8in away from me. Made no difference... pretty much what I expected but it was worth the try. Convinced now the issue is not with the ignition but the flame sensor or the circuit board.
But I am now thinking of removing the orifice installed as part of the NatGas to LP conversion and check it for burrs or small obstruction. The one time I did get it running you will recall I got a blinking Yellow LED indicating weak flame. Back in a few...
MCELROY COOL PACK 20 (A55745)
MCELROY COOL PACK...
2018 DRAGON 150 BBL ALUMINUM TRAILER (A55745)
2018 DRAGON 150...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
Informational Lot - Financing (A55315)
Informational Lot...
2022 BRAZ0 40FT PIT BOSS BELLY DUMP TRAILER (A54607)
2022 BRAZ0 40FT...
UNVERFERTH 210 (A53084)
UNVERFERTH 210...
