My New Kubota ZD1211 Mower
   / My New Kubota ZD1211 Mower
I cut all 3 of them completely off today & it's a lot better :D
I haven’t looked at mine. Is it possible to just remove them so they can be re-installed?
   / My New Kubota ZD1211 Mower #102
I haven't looked at mine. Is it possible to just remove them so they can be re-installed?
Yes Sir, their bolted on across the back of deck on the ZD mowers.
I think the F series mower decks has metal shields bolted on instead of rubber.
Good deal. If we ever start getting rain again ........ I may remove mine for a trial.
Are you seeing any increase in clippings getting to your radiator?
   / My New Kubota ZD1211 Mower #104
This has been the wettest summer ever here in North Ga.
I mow 3r4 evenings a week weather permitting, then it's time to start all over.
The clippings shoots out the back now & don't linger around getting sucked up into Radiator Draft :D
It helps my radiator stay clean much longer.
I envy your rain. I’m still just 19” for entire year and virtually zero since early July.
   / My New Kubota ZD1211 Mower #106
We've gotten 38" this year so far, but normally it's closer to your 19" because we rarely get much from May thru August.
   / My New Kubota ZD1211 Mower #107
Did you ever remove them? I hate the windrowing that my 72'' RD leaves... on the front yard
   / My New Kubota ZD1211 Mower #108
I first cut the rubber flaps off, then unbolted & removed them later.
Flipped the metal guards upside down & bolted them back on w/o rubber flaps.
It made a huge difference dispersing clippings a lot more evenly.
BD ..... I'm wondering if you see any difference in clippings clogging of the radiator screen, after you removed your flaps.
   / My New Kubota ZD1211 Mower #110
I can actually mow a little longer before having to stop, dump screen & clean radiator out.
I’d guess I can mow 3hrs or so before it starts running Hot.
Frontier FM2015 (A53314)
Frontier FM2015...
2020 LOAD KING JBTR-56 (A55745)
2020 LOAD KING...
2022 FREIGHTLINER CASCADIA SLEEPER (A56129)
2022 FREIGHTLINER...
2013 BMW 528I (A47477)
2006 MACK MR CAB & CHASSIS (A56129)
2006 MACK MR CAB &...
16' Driveway Gate (A53316)
16' Driveway Gate...
