My Tractor Mechanic is not happy
   / My Tractor Mechanic is not happy #1
Mitsubishi MT2001D
I may have bought a 1955 Oliver Super 55 with four implements, delivered, for $2,800.
My mechanic is rolling his eyes because it is elderly and it is gas. But he was at his folks' place or wheat harvest,
I was unsupervised!!!
Is he going to be right in the long run? Did I want a diesel??
   / My Tractor Mechanic is not happy #2
It depends on your intended uses for the tractor.
   / My Tractor Mechanic is not happy #3
I had a gas Oli. It was a fine tractor. It used more fuel than a diesel would. Probably didn't have the same torque characteristics as a diesel.
I would prefer a diesel, but, if I only had one tractor, and no other diesel, I would not be ashamed to own a gas tractor, they start easier in the cold too.
Best,
ed
It is to be the dedicated bush mower tractor. I have a 24hp 4wd Mitsubishi with a F/E loader to do everything else. I just HATE dealing with the mowing deck!!!
Best,
ed
So just to mow the pastures, I am good?? Have a diesel with a f/e loader already
   / My Tractor Mechanic is not happy #7
My first tractor was a 1959 Farmall Cub. I didn't know what I wanted and a friend of mine said this was a good place to start. I loved that tractor and wish I still had it because the $1800 I sold it for is long gone.
It put out a (massive) 12 HP but the machine was incredible when you pushed it a little. I would skid 25' pine logs with it's 2 point hitch and it didn't miss a beat. It was gas and incredibly reliable.
   / My Tractor Mechanic is not happy #9
I think the old Oliver is more than up to pulling a rotary cutter. You should have no problem for that purpose.
   / My Tractor Mechanic is not happy #10
Oliver Super 55 Power
Drawbar (claimed):23.3 hp
17.4 kW
PTO (claimed):32.65 hp
24.3 kW
Drawbar (tested):29.60 hp
22.1 kW
Belt (tested):34.39 hp
25.6 kW
Mechanical
Chassis:4x2 2WD
Brakes:mechanical disc
Open operator station.
Transmission:6-speed unsychronized gear
Dimensions
Length:120 inches
304 cm
Height:71 inches
180 cm
Operating weight:3,400 lbs
1542 kg
Ballasted weight:5,500 lbs
2494 kg
Front tread:48 to 76 inches
121 to 193 cm
Rear tread:48 to 76 inches
121 to 193 cm
2019 Ram 3500 HD (A56435)
2019 Ram 3500 HD...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
2006 CATERPILLAR D604S GENERATOR (A58214)
2006 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
KOMATSU D155AX-8 CRAWLER DOZER (A60429)
KOMATSU D155AX-8...
CATERPILLAR CB13 SMOOTH DBL DRUM ROLLER (A60429)
CATERPILLAR CB13...
