well, yesterday I got the spare rims primed and painted, and then left them to cure. I replaced ignition components, plugs, wires, etc.. must say that I don't like the new 8mm cables tsc is selling. they are still cut to fit.. but have a soft inner core, and are so soft that they are difficult to push thru the boots for the dizzy cap, even with som silicon lube it was a fight on each one.
filled the cooling system back up, did a dry test of the starter / solenoid, as well as polarizing the genny and installing the battery. had a gollon of gas in her and decided to throw the seat on and start her up as a test.. but then noticed a coolant drip
drained coolant and found I didn't get all of the rust chips off the water pump nozzle, and to top it all off managed to nick the hose removing it.. didn't fell like putting a damaged hose back on.. so that killed the rest of the evenings work..
running by cnh to get a new hose today.. hopefully will get that all installed and test fire her up this evening.
might get rims on firday morning/mid afternoon before work. if so.. then I'll likely get the fenders on as well..
soundguy
