MY2012 5085M ordered today!
   / MY2012 5085M ordered today! #311
Haven't been keeping up very much here... must be summer!
Bummer with the loader! :mad: Those first scratches and dings are always hard to take..
Extendable draft links and the hyd top link with the remote EH 3pt are certainly more "user friendly" than any of the QH options. JD, Pat's, etc. etc. Especially if you've got a whole shed full of implements!! :D
If I had more hardware to hang on the 3pt - I'd probably sell my Cat II hitch. Since I only work with baler, rake, tedder, MoCo for 2-3 months out of 12.... the quick hitch stays on the tractor for most of the year on the rear blade.
AKfish
Stopped by the dealer to check on the progress. Apparently they were missing a "special" bolt with a built in washer, so they had to order that overnight. Should be here tomorrow. Replacement stickers did not come in either today.
Showed the parts counter the single point connector and after digging through the hydraulic part bins, which would have required 2 adapters to make it work, we decided that the cleanest look/function would be for me to bring in my grapple hoses, and they will cut off the #6 JICs and crimp female ORFS fittings onto them.
They also had a open station MY2012 5085M that had just been dynoed. It made 76hp, so I should be very happy that mine made 85hp on that same dyno! I think think there might have been some sort of operator error.
Turns out the only 85" global carrier buckets he has in stock are the SD ones without the grapple brackets. But he has a H340 loader on a pallet with the HD one. Trying to talk the dealer into letting me have that one. :D
AK, yeah, I think I'll be happy with the EH hitch controls and extendable links.
   / MY2012 5085M ordered today! #314
Thanks Zebra! Hopefully the dealer will throw in the needed adapters. I measured the I.D.s and the ORFS is 3/8" and the JIC one is 5/16", which seems a bit odd. The hoses on the grapple are 1/4".
Thanks. Those extra brackets look like they could be useful to various pulling/chain connection points. I have asked the dealer to pull one for me to look at next to the 73 incher.
Kind of hard to measure a female thread for athe male OD. So 5/16" might be the root size. Easiest to find a fitting that threads in then remove and measure it.
I did see the dealer suggested crimping the correct fittings to your hoses. That would be the best, less fittings. Everything is going ORFS anyway.
If you don't mind shipping, I've seen new JD HD global buckets as low as $650. Seems to be NOS dealer wants to clear.
I was finally able to pick my 5085M back up with the H260 loader installed. He swapped out for a 85" HD bucket as well. Turns out the one one he had in stock without the grapple brackets (BW15546) WAS the HD one.
Still on the trailer
Other side
Triple function single point connector
Different angle. Mounted this way it doesn't stick out that far I think
3rd function single point
From below. I like the "skid plate"
HD bucket side shot
Head on. Also showing brush guard
Bucket teeth
Grapple with the stands and implement side single point connector
They are having some kind of customer appreciation bbq next Thursday where they are bringing in a bunch of Kubota tractors for customers to play around with. So we haven't done the paperwork yet as each customer will get a $500 voucher towards the purchase of a Deere. :D
   / MY2012 5085M ordered today! #316
Very nice Peter,I like :thumbsup:
Thanks Murphy!
I was able to put on the grapple in between showers, then it started pouring down. Was able to snag a few shots.
I thought those hoses looked really long. I should have had them cut off more before putting on the new connectors....
   / MY2012 5085M ordered today! #318
I personally saw 2 5085Ms today open station, boy were they nice utility tractors. Drove me both around and they were extremely comfortable. They still had the original "window" sticker on it, price was torn out but they had 500 and 700 hours on them standard duty 3 point went for 17k guy bought both it was at an auction.
   / MY2012 5085M ordered today! #319
Thanks Murphy!
Pete, What does that grapple weigh??? Looks like a real tree eater.Oh Boy!!
972 lbs according to Owner's manual.
I hope to try it out this weekend along with my stump grinder unless it is too wet.
2016 FREIGHTLINER CASCADIA (A55745)
2016 FREIGHTLINER...
2008 Chevrolet Impala LT Sedan (A55853)
2008 Chevrolet...
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A55745)
2013 TEXAS PRIDE...
ALTEC CP12LF HYD (A52707)
ALTEC CP12LF HYD...
2015 Vermeer SC362 Stump Grinder with 2018 S/A Flatbed Trailer (A53421)
2015 Vermeer SC362...
New/Unused Self Dumping Hopper (A54865)
New/Unused Self...
