Buying Advice need advice for new kubota
   / need advice for new kubota #41
The CK 20, a big bad gnarly tractor :laughing::laughing::laughing::laughing: I know the BX line is a SCUT and the CK 20 is a CUT, but it's the smallest tractor Kioti currently makes (wait a few months and the SCUT line will be at the dealers if it's not there now). A previous member posted that you will either buy a bigger tractor than you think you need, or trade the first one in and buy a bigger one later, I fully agree with that.
My point is simply if you're going to spend that kind of money, you can get a lot more tractor that will do all the things the little BX will do plus %1000 more! They are both small tractors that are maneuverable and easily stored. One is just capable of so much more and costs about the same.
Like the OP, I also have 3 acres, my driveway is paved and 26' X 100', I used to cut the lawn (3 hours) with a 20hp JD home depot special and clear the snow with a 28" 10hp Murray snowblower. I had no idea of all the things I would do with a tractor, but I'm currently on my second tractor and seriously regret not buying the next frame size up with double the lift capacity of the tractor I have, and mine is about 4 time the capacity of the BX2360! Buy as big as meets your budget IMO, and I think a lot of very experienced people on TBN will agree with that.
After using our BX2200 for several years, we decided to "upgrade" to a CUT and even sold our BX. After looking at CUTs, we brought a new BX2660 home and after four years have no desire for anything bigger.
I guess I am an experienced person in the minority.
Again; "Bigger isn't always better, sometimes bigger is just bigger."
   / need advice for new kubota #42
I only have some of the info you need, so you may not be able to explain the huge difference I see.
The gas mower is 21 hp B&S, I run it at full throttle (but no tach so I don't know the RPM). The mower deck is three blades, 42" cut.
The diesel is 23 hp (17 hp at the mid PTO which drives the mower, but I assume the engine hp is what's important.) I run it at about 3000 rpm. The mower deck is three blades, 54" cut.
The gas is 2hp smaller, but also cutting a full foot less grass each pass. The difference between the "power" of the two is night and day, from the day they've been new. I'm not exaggerating - there really is a huge difference. I'd always attributed that to diesel torque everyone talks about, but after reading your posts, that doesn't seem to be the case. Can the extra 2hp be making that much difference??
How big of a role does engine displacement play? I don't know the displacement of the two, but the B&S gas is only two cylinders, the Kubota diesel is three cylinders.
The 21hp B&S will have less hp at the pto, just like your other tractor. But as stated above, gasoline engine manufacturers really 'stretch' the ratings of their engines, so I doubt if it is a true 21hp. May just be the smell of diesel, it is intoxicating! Philip.
   / need advice for new kubota #43
I think $15K is a lot of money for a little tractor. Before I get yelled at, I'm saying little, not bad and maybe little is what you want and need, but you could get a whole lot more tractor for that kind of money.
Eh, that $15K includes a deck and a front mount snowblower -- the latter is not inexpensive, by the way.
I was convinced I was buying a new kubota to replace my JD. I really only shopped the other brands to satisfy myself that I wasn't jumping into something blind and had done my homework. I found that the world has more than (Kubota) orange and JD green.
Before spending that much money, go look at a Kioti CK20 ...
I can't believe that you are recommending a Kioti after all of the issues you had with yours. I mean, your new tractor had to be split TWICE in the first hundred hours to first repair the HST and then a fluid leak? In the link below you stated "Tractor now has 107 hours at least 10 of which is from the dealer fixing it" and you are suggesting this brand in the Kubota forum?
http://www.tractorbynet.com/forums/kioti-owning-operating/218090-my-new-ck-30-a-4.html
Wrooster
   / need advice for new kubota #44
Wrooster
That is great stuff! Everyone needs to check out that link and the whining. Here is a copy paste from kiotiken (wanna be Kubota orange, now I understand) Philip.
From Ken:
Well, I couldn't resist the $1500 rebate Kioti was offering on cabs for the CK27-35, so I pulled the trigger and had one installed. I've had the tractor back for a week and I'm getting used to the cab, so here's a few pictures and a bit of a review.
Like everything else I buy, nothing goes smoothly, and this cab is going to fit right into this category quite nicely. I don't have too many good things to say about it so I'll break the issues down between Kioti issues and installation issues. I've got a call into the dealer and will be discussing those issues today, so I won't get to far into them in the hopes they'll be fixed.
First, the good. Very nice looking cab (from the outside). It's warm. It's a little lower than the tractor was with the ROPS. Sorry, that's all I can think of.
Starting with the Kioti issues. My dealer didn't have one of these set up, and neither did any of the other dealers around me, so I relied on the brochure from Kioti (http://www.kioti.com/attach_files/Pr...compressed.pdf) and any pictures I could find on the internet (Thanks KiotiKarl! TractorByNet.com - Compact Tractor Forum). Unfortunately, the specs don't match the product. Listed as standard features are:
1) Pre-wired audio den with speakers - No speakers included, dealer DID install them.
2) Side/Rear view mirrors. - No Rear view mirror, although, there does seem to be a place to attach one. (first pic)
3) Cup holder - No, not for the CK27-35 version. Pics from KiotiKarl show one for the CK20 version. You might say "who cares", and you may be right, but many mornings I've gone out with a coffee in a travel mug for some seat time.
4) They didn't ship all the parts, I'm now waiting on the hardware for the front windshield, my dealer wired it shut in the meantime.
Now for the installation issues. Some may end up moving to the Kioti issue category.
1) The floor is VERY sloppy, it doesn't seem to fit, seems to have been installed in the wrong order (I would guess it should have been the first thing installed, not the last), and will allow water to penetrate and rust out the floor. See pic 2 & 3.
2) The insulating matting is missing around the centre console. It is clearly visible in the picture from KiotiKarl, pic 4, but it is missing and I can stick my hand through the floor, pic 5. Kioti went to some trouble to make the material tight to all control levers, so I'm pretty sure they wouldn't have left gaping holes right beside the engine compartment. This material is to reduce noise after all.
3) The material under the seat doesn't fit properly, pic 6.
I'll leave it there, I may update more later, but I do really like my dealer and he deserves the chance to make these issues right as well as a few others we don't need to get into.
To end on a positive note, I asked for a rear wiper. I was told there wasn't one available. My dealer did figure out how to mount one for me. I also inquired into adding a second remote but then decided to put it off until I buy a snowblower. When I got the tractor back, my dealer had gone ahead with it because they would have had to remove the cab to do it in the future. This may have been a big issue for some, but I appreciated it and I'm glad it only cost me $500 now instead of $1000 next year. He also told me I could pay for it later if I wanted to, which I didn't.
Dear Ken, please don't push the Kioti stuff to us anymore. I would not wish these issues on my worst enemies. Philip.
   / need advice for new kubota #45
TripleR,
I've read hundreds of your posts and generally think you're a voice of wisdom in the TBN community. I'm struggling with this post however. Do you care to list your tractor arsenal that you've built between your various farms? (I'm not sure I want to dig through all your previous posts like others have done for me) If the BX won't do a job for you, you jump on the Mxxxx or one of the other half dozen machines you have. Of course your BX does everything you ask of it, you only ask what a BX is good for, not everybody is so lucky.
   / need advice for new kubota #46
Wrooster
Yup, no doubt, I've had issues, most have been minor, with the exception of the hst that was replaced because it "crept" forward instead of returning to the neutral or stopped position. Every manufacturer has issues, it's the way they handle them that counts. Unlike dealers and Kubota who have refused to acknowledge the jerky 3pt hitch issue on the Lxxxx tractors (what I would have been stuck with if I'd bought the tractor I originally set out for), Kioti has been awesome at fixing everything that comes up. My dealer either fixes little issues on site or hauls it off, completely free, and returns it a day or two later. I've now got 160 hrs on the clock and 3 year left on my 4 year warranty.
From Ken:...
Happily Kioti orange is more accurate. My CK30 out specs, out works and is a luxury tractor compared to the L2900/L3200 that I was shopping at the time (oh ya, did I mention it was slightly cheaper too?).
I'm flattered you guys have spent so much time researching my previous musings here on TBN, almost like you feel threatened if somebody doesn't blindly say Kubota is the only answer. As far as my whining, yes, I was disappointed initially by the Kioti Cab and installation. Again, it's how it's handled that's important. My dealer came back and spent 4 more hours with 2 guys and fixed the instal. (I mostly blame Kioti for lack of dealer training on this product). As for the missing features, what a pain, but again, Kioti addressed each one of them and made good on them all. Then, for all my trouble, they sent me a super nice jacket, really nice hoody, and a nice ball cap. The cab is now perfect and I'm a happy guy, what more are you looking for when you buy something?
Now guys, as far as pushing Kioti, you need to work on your reading comprehension a little. Read my previous posts, I'll summarize to make it easier.
Spending 15K (implements or not) without first looking at ALL the options if foolish. Look at Cub Cadet, Yanmar, JD, the new Kioti SCUT (CS2410: Kioti's First Ever Subcompact Tractor - TractorByNet.com) and anything else you find.
I stand by what I said earlier, at that price, buy a tractor that can do what you want now, and what you may want to do later.
   / need advice for new kubota #47
Unlike dealers and Kubota who have refused to acknowledge the jerky 3pt hitch issue on the Lxxxx tractors.
As far as I know, there are no jerky 3pt hitch issues on the Lxx40 tractors, and certainly not on my L3940. Not sure what you mean by Lxxxx. Philip.
   / need advice for new kubota #48
I'm really not trying to pick a fight, only offer some advice to the OP. I'd be willing to bet you know full well that the jerky 3pt hitch applies to the economy L series and not the Grand L series, almost every Kubota person here on TBN does. I did mention the two models I was looking at L2900 and L3200 (if memory serves), both affected by the issue. I'm not sure why you're trying to be so difficult instead of constructive with your advice to a new member and potential new tractor owner.
   / need advice for new kubota #49
Yes, I know that, but you were not clear when you said 'Lxxxx tractors', which would include my L3940, which is not the case of the Lxx40 series of tractors. Philip.
   / need advice for new kubota #50
It was simply a point. All tractor manufactures have issues so I don't think it's helpful to a discussion to point to one tractor experience on one model from a manufacturer. Take a jump over to the Kioti forum and you'll find very few issues and lots of smiling faces.
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A53473)
2022 NEW HOLLAND...
2011 DOOSAN G40 GENERATOR (A53843)
2011 DOOSAN G40...
2017 Caterpillar D5 K2 LGP (A53473)
2017 Caterpillar...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
2019 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A53843)
2019 GENIE GS-1930...
