Backhoe Need Max PSI Setting for LW-8 Backhoe Relief Valve
   / Need Max PSI Setting for LW-8 Backhoe Relief Valve #11
Rob, You always do the neatest things. Easy to smile reading your posts. Good to hear you!
Richard
   / Need Max PSI Setting for LW-8 Backhoe Relief Valve #12
How do you find the LW-8? I have a LW-7 and while it is serviceable the control valves are very jerky, especially the swing. This BH is several years old and things may have improved some. Also I modified mine to run off the tractor hydraulics.
When ordering a new narrow bucket for mine I found out that the LW series Backhoes are made by several factories in China and not all are the same. I ordered a bucket from Circle G and it did not fit and had to go back through Chip to have him order one from the original maker.
The LW-8 works good ... lots of power and more reach than the smaller Nardi backhoe.
Although it lacks the refinements and rigidity of the Italian backhoe, it digs great. This one was purchased in 2007 by my friend Scott when he and I got together and bought his tractor and Loretta's tractor, plus a whole container full of implements for each of us. He sold his tractor and I ended up buying this backhoe from him along with a bunch of implements. So it is probably older or as old as your LW-7 maybe?
If you click on that link in my very first post in this thread, you can read more about the LW-8 and the Diamond shaped sub-frame I made for it to fit the 554 Kama.
   / Need Max PSI Setting for LW-8 Backhoe Relief Valve #14
The hydraulics can be tamed just by adding restrictors in the circuit you want to control with no sacrifice to power.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
NIPPON HYD THUMB (A52706)
NIPPON HYD THUMB...
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
2014 Chevrolet Impala Sedan (A59231)
2014 Chevrolet...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
2023 CATERPILLAR D3 LGP CRAWLER DOZER (A60429)
2023 CATERPILLAR...
