New 2024 Cub Cadet Ultima ZTXS5 54
   / New 2024 Cub Cadet Ultima ZTXS5 54
A piece of stiff wire with a hook bent in one end and hooked over the top of the defelecter shout, with the other end attached to something on the deck. Done !
So far, the piece of 1x4 the dealer stuck in there when he delivered it is working fine and staying in place, I'm just trying to come up with something that looks a little more "professional"...
If you ordered through Cub Cadet and the dealer won't provide the part you bought and paid for, maybe contact Cub Cadet directly to complain about the dealer's service. The downside could be the guy acting even worse next time you go into his dealership?
That's a good thought. I'm pretty much done with this dealer anyway...
Interesting. Our local Kawasaki dealer always has the oil filters in stock for our mule.
I bought a similar cub cadet ZT last June and never got to use it. It arrived with shipping damage, so I sent it back. Discovered they were back ordered with no shipping date available. So I ended up buying a Stihl zero turn from a local dealer off the floor. It has the four wheel suspension and I really like that because I’m mowing off yard native grass and the ground isn’t smooth. So far I’m pretty pleased with the unit overall and believe the suspension makes a huge difference. Hopefully a suspension seat will help to smooth out the ride on your machine.
I haven't looked closely at ZTR suspension systems, but it seems there are two types (well, three, if you count suspension seats). One has a suspended operator platform and the wheels are fixed, and the other has springs on the front wheels.
It always seemed to me that having the springs on the wheels would cause the mower deck to bounce up and down and make for an uneven cut. However, this must not be the case, because I have never seen a complaint about it.
   / New 2024 Cub Cadet Ultima ZTXS5 54 #34
My Stihl has springs on all 4 wheels. I’ve never had issues with the deck bouncing. They are basically repainted and rebadged Ferris mowers.
   / New 2024 Cub Cadet Ultima ZTXS5 54 #35
Our Simplicity Citation has no issues with the deck bouncing. Our yard needs a suspension ZTR too due to the bumpiness.
I guess, when you think about it, having no suspension could (and does) cause uneven cut too, when the front wheel(s) go into a bump, but the rear wheels aren't there yet. So the suspension can't be any worse and is way better in operator comfort.
Tried loading the ZTXS5 on the flatbed trailer today. It cleared the 15 degree breakover angle on the dove tail with no problem. Still have to think about what to use for tie down points. Maybe either through the front wheel assemblies or the weight bracket on the front, and either around the frame or the hydro connecting bar on the rear.
Front wheels are 28" apart which is 2" narrower than my ramps, but it still works.
   / New 2024 Cub Cadet Ultima ZTXS5 54 #39
Looks like not much room for error. Maybe throw a sheet of plywood to span the ramps before you load and unload you could put the plywood sheet on the trailer and drive the machine on it to secure it during travel.
I'm kind of used to it. I've been using this trailer for my JD 2520 for years and it fits the same way. If it was bad enough to bother me, I would just remove the assist springs on the ramps, which would allow the ramps to slide closer together by about 8".
I'm hoping to never need to put the mower on the trailer....
1992 GROVE CRANE (A52576)
1992 GROVE CRANE...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
2012 John Deere Gator HPX 4x4 Utility Cart (A51691)
2012 John Deere...
2014 Dodge Charger Sedan (A51694)
2014 Dodge Charger...
2018 Chevrolet Camaro 1LT Coupe (A51694)
2018 Chevrolet...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
