New Low Sulfer Diesel in 2006 -PROBLEMS?
   / New Low Sulfer Diesel in 2006 -PROBLEMS? #41
It really does not make any difference, the USA and Canada are going to ULSD in 2006 no matter what anyones opinion is. As are Europe, India, China, Brazil, etc. That represents over 3/4 of the entire human population of the world that will be using ULSD. The majority of the backward countries still using rot-gut high sulfur diesel fuels are third world countries in Africa, Asia, and the Middle East.
The facts are simply that diesels would have no future whatsoever in North America without ULSD. ULSD is an enabler that allows diesels to continue working on through the future.
Those that are afraid that the government has taken the sulfur out of their diesel fuel can always just add 100 milliters of 10 Molar concentrated Sulfuric Acid to each tank at fillup to bring the sulfur level back up.
BTW, the compounds removed by the severe hydrotreating of ULSD that causes the reduction in lubricity are NOT sulfur, they instead are nitrogen and oxygen.
   / New Low Sulfer Diesel in 2006 -PROBLEMS? #42
Don't believe me?
Read what Chevron-Texaco--Oronite has to say about it then:
http://www.chevron.com/prodserv/fuels/bulletin/diesel/L2_2_5_rf.htm
"Many diesel fuels are good boundary lubricants. This is not due to the hydrocarbons that constitute the bulk of the fuel. Instead it is attributed to trace amounts of oxygen- and nitrogen-containing compounds and certain classes of aromatic compounds. Evidence for the role of trace quantities is the fact that the lubricity of a fuel can be restored with the addition of as little as 10 ppm of an additive."
"Lubricity enhancing compounds are naturally present in diesel fuel derived from petroleum crude by distillation. They can be altered or changed by hydrotreating, the process used to reduce sulfur and aromatic contents. However, lowering sulfur or aromatics, per se, does not necessarily lower fuel lubricity"
   / New Low Sulfer Diesel in 2006 -PROBLEMS? #43
</font><font color="blue" class="small">( Don't believe me?
"Lubricity enhancing compounds are naturally present in diesel fuel derived from petroleum crude by distillation. They can be altered or changed by hydrotreating, the process used to reduce sulfur and aromatic contents. However, lowering sulfur or aromatics, per se, does not necessarily lower fuel lubricity" )</font>
What about the following 2 paragraphs that followed that excerpt you quoted:
</font><font color="blue" class="small">( The use of fuels with poor lubricity can increase fuel pump and injector wear and, at the extreme, cause catastrophic failure. Such failures occurred in Sweden in 1991, when two classes of "city" diesel with very low sulfur and aromatics contents were mandated. Heavy hydrotreating was necessary to make these fuels. The problem was solved by treating the fuel with a lubricity additive. )</font>
As many have been saying, the lubricity additive may need to be added to the new 2007 fuels, either by the supplier or the end user.
Also:
</font><font color="blue" class="small">( Many users were concerned when the U.S. Environmental Protection Agency (EPA) mandated on-road low sulfur (0.05% mass, maximum) diesel fuel and when California Air Resources Board (CARB) mandated low aromatics (10% volume, maximum) diesel. But there is no documented evidence that the use of these fuels, as a class, has led to increased wear, much less catastrophic failures.)</font>
However, these fuels are not the same as the fuels that will be required come 2007, so although there have supposedly been no US catastrophic failures to date, we have no idea what impact the yet-to-be-released 2007 fuels will have.
   / New Low Sulfer Diesel in 2006 -PROBLEMS? #44
Simple, I had mistakenly assumed that you already knew that all the producers of ULSD add a couple of ppm of lubricity enhancers to bring the lubricity higher than 3100 grams on the SLBOCLE (Scuffing Load Ball on Cylinder Lubricity Evaluator) test. And that all this has absolutely NOTHING to do with 15ppm of elemental Sulfur in ULSD whatsoever.
"However, these fuels are not the same as the fuels that will be required come 2007, so although there have supposedly been no US catastrophic failures to date, we have no idea what impact the yet-to-be-released 2007 fuels will have."
What do you mean? Texas and California are already using them now And Texas and California account for the consumption of 25% of all the diesel fuel in the USA.
And yes you are absolutley correct, Sweden has been using 10ppm ULSD without aromatics now for over 15 years now with out any problems.....
   / New Low Sulfer Diesel in 2006 -PROBLEMS? #45
SkyPup, it looks like most of us will have to agree to disagree with you. I don't see anyone who is advocating more pollution or saying that it is a bad thing to reduce pollutants. However, there sure seems to be a vast amount of information available from chemical companies, refineries, diesel advocate groups, and researchers that flat contradict you. Since you paid your hard earned cash for your diesel engines, you are most certainly entitled to use whatever you wish in them.
Since I spent my hard earned money for my diesel engines, I'm going to have to side with the reports from the refineries, chemical companies, the military, and the diesel advocate groups and hope that in the end, when sulphur content is greatly reduced, that they add some sort of lubrication substitute at the refinery. I personally do not want to have to have to add a lubricant at each fill up. That would seem to me like having a 2 cycle engine, in that it is at the least, annoying, and easy to forget. I'm basically finished with this particular subject for now and have done all the research to satisfy what I feel I need to know on the matter at this particular point in time. As time passes, I'll have to keep an eye on the outcome of who will be responsible for making up the lost lubrication and make sure that I don't prematurely have engine problems.
I respect your stance, I just disagree with your position on the lubrication factors. I do not disagree with your stance that more pollutants should be removed from our fuels. See, I don't totally disagree with you. /forums/images/graemlins/grin.gif
   / New Low Sulfer Diesel in 2006 -PROBLEMS? #46
No problem, I haven't found two people in the world who think alike yet! /forums/images/graemlins/wink.gif
BTW, please don't forget that ULSG is also mandated in 2006!
You cannot have modern gasoline or diesel engines without first having modern gasoline and diesel fuel technology! /forums/images/graemlins/grin.gif
   / New Low Sulfer Diesel in 2006 -PROBLEMS? #47
I will offer my opinions about the intro of ULSD but I doubt that those who WANT to worry about it will be reassured.
When the first sulfur reduction took place back in '93 or so, my family had a small fleet of trucks. We'd heard the stories about how the lack of sulfur in the fuel was going to cause injection pump failures left and right. It wasn't long before the first one bit the dust, a 3208 Cat. But the autopsy showed that the failure was caused by rust, not a lack of lubrication. That sulfur reduction was much more drastic than the upcoming one. So unless there was a tremendous surplus of sulfur in the fuel in '92 and now we are down to the last little bit that's actually doing the "lubricating", this newest reduction is nothing compared to the big one of '93.
We had some maintenance done at a small shop that had, probably, 100 or so trucks that it serviced. I would ask the shop manager from time to time if the dreaded 'sulfur-shortage' injection pump failures were showing up. To my knowledge, they never had one.
You can find refiners' web sites that support both positions. BP calls sulfur a lubricant; Exxon says it isn't, so I'm not sure of the value of using the internet as proof one way or the other.
I am not going to worry about it. I will use whatever comes out of the pump. If indeed lubricity is reduced, I am confident that that problem has already been addressed since California has been using ULSD for quite a while. I think the elimination of sulfur should be 100%, cost not withstanding. From what I know, it's a tramp element in crude that, if it weren't already there, we sure as [censored] wouldn't be adding any to our fuel.
   / New Low Sulfer Diesel in 2006 -PROBLEMS? #48
</font><font color="blue" class="small">( "Lubricity enhancing compounds are naturally present in diesel fuel derived from petroleum crude by distillation. They can be altered or changed by hydrotreating, the process used to reduce sulfur and aromatic contents. However, lowering sulfur or aromatics, per se, does not necessarily lower fuel lubricity"
)</font>
The second paragraph is the clencher. Your doing a bit of walking around the issue. As that report states.. it isn't the sulfuritself, that is reducing the lubricity when removed.. but the very process of removing it, lowers the lubricity, by effecting other chemicals int he mix. What this means is what we have all been saying.. lowering the sulfur content lowers the lubricity..... Makes little difference that it isn't the sulfur itself that is the lubricant if the act of removing it removes the other compounds that ARE the lubricant.. It's one of those unintended consequence issues.
I'm with Dargo and the other, We can agree to disagree.. especially since your 2nd paragraph even lays it more plainly out on the table about the reduced lubricity of fuel that is treated to remove sulfur....
Soundguy
   / New Low Sulfer Diesel in 2006 -PROBLEMS? #49
</font><font color="blue" class="small">( Sulfur is not a lubricant, it is a bad contaminant. The severe hydrotreatment utilized in its removal also removes many of the other water soluable polar compounds that do provide lubricity. In order to correct for the lubricity compounds removed, the ULSD producers add back enough lubricity back to the refined fuel so that the lubricity remains higher than 3100 grams on the SLBOCLE (Scuffing Load Ball on Cylinder Lubricity Evaluator) test. )</font>
Many posts after you said this, some posted evidence of just what you said in this post. It's not the sulfur itself, it's the other compounds that provide the lubricity, and the treatment removes those. Someone, end user, or distributor, will have to add some lubricity. I got what you said and then read on to see misunderstanding.
I certainly hope you're right that the producers add back lubricants. John
   / New Low Sulfer Diesel in 2006 -PROBLEMS? #50
No problem, I've known that fact for years now. It helps to have many years of basic organic and biochemisty education and experience as well as relatives in the industry.
Like I said, California and Texas use 25% of all diesel fuel in the USA and they have been using ULSD with no problems. Repeat -> No Problems!
Why do they have No Problems you ask?
Simply due to the fact the producers add a couple of ppms of short chain fatty acids to replace the lost lubricity from having to super catalytically crack the high percentage of aromatic hydrocarbon double bonds with severe hydrogenation and then hydrotreat the residue to remove the water soluable polar compounds (sulfur, nitrogen, and oxygen motieties). One reason for this mess is the extreme low quality of crude available on the market for US refiners. Crude from Venezuala (CITGO) is so poor quality that it is loaded with sulfur and aromatics and receives extreme heavy duty refining treatment. This is NOT the case with Sweet Texas crude or most Gulf of Mexico crude grades, which is much higher paraffinc stock with low amounts of contaminants like sulfur and aromatic hydrocarbons. Remember, the best quality diesel fuels are Straight Cut from high grade crude sources, not hydrocracked and hydrotreated from low grade crude stocks.
BTW, the super high quality Swedish fuel that all the ULSD questioning people are afraid of is 65 Cetane, No Aromatics, 10ppm sulfur, and the absolute highest quality #2 diesel money can buy anywhere in the world! /forums/images/graemlins/laugh.gif
Those who believe that the API and major oil companies are NOT aware of this fact can simply go on purchasing and adding aftermarket additives to their diesel fuel. /forums/images/graemlins/smirk.gif
   / New Low Sulfer Diesel in 2006 -PROBLEMS? #51
Here is a quote from Shell Canada................Just buy the fuel and quit worrying about it!!!!
Take care
Will
As of Oct. 1, 1994, Shell and other major Canadian refiners began selling only low-sulphur (0.05 per cent) diesel fuels, under an agreement with the federal government to reduce particulate emissions.
Shell Fuels advisor Colin Britton says some concerns have been raised in the United States about loss of fuel pump lubricity, due to sulphur-content reductions. But he says he sees no cause for concern in Canada, because Shell's Scotford Refinery near Edmonton has been manufacturing ultra-low sulphur diesel fuel (0.01 per cent) for more than a decade without experiencing any signs of lubricity problems.
   / New Low Sulfer Diesel in 2006 -PROBLEMS? #52
Hi,
I was working at a Hi-Volume highway center when LSD came out, and for the first few months a few of the new ( 1994 ) Powerstrokes, Cumins, etc had lubricity problems. The the Gas companies got it together and it has been fine since!!
Take care
Will
   / New Low Sulfer Diesel in 2006 -PROBLEMS? #53
WilliamBos, I will have no problem if I am provided with a written warranty from Colin Britton giving me a guarantee to replace or repair of any damage caused from lack of lubrication from use of their fuel. Otherwise, if they are not willing to put their money where their mouth is, I will rely on the information I've been able to read from a multitude of other sources.
If someone is sure of their claims, there is absolutely no reason whatsoever for them to not provide such a written warranty. If they will not, they must be simply providing "lip service", which does me no good. If you can show a written guarantee as to such, I'll have no problem using their products at any time. If not, I'll have to lump that claim in with all the others that talk a big stick but simply disappear when it comes down to backing up their claims. I look forward to seeing a written guarantee from your source to cover any damage caused by lack of lubricity of their diesel fuel. Thanks!
   / New Low Sulfer Diesel in 2006 -PROBLEMS? #54
Well you will just have to use it and find out!! WONT YOU!!!!!!
Thats what I would and have done!! Rather than worry yourself to death on it use it, if the performance of your vehicle suffers from it then make some changes , other than this why worry about something before it happens!! We have been using it up here for a while with no worries, and if it works for us, then it will work for you!!!!!!
GRRR!! I am done with this debate!!!!!!!!!
/forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif
   / New Low Sulfer Diesel in 2006 -PROBLEMS? #55
This has been entertaining reading /forums/images/graemlins/cool.gif… don’t stop yet… /forums/images/graemlins/laugh.gif
The subject however reminds me of everything that was said when lead was removed from gasoline.
I think products generally improve with time and we will all end up using whatever comes out of the pump /forums/images/graemlins/shocked.gif… even if its soy peanut or french fry oil filtered through an old sock /forums/images/graemlins/wink.gif… some will use additives some won’t. Life goes on…we may end up using hydrogen /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif. KennyV.
   / New Low Sulfer Diesel in 2006 -PROBLEMS? #56
In the Exxon lube oil community, we went through similar research and all on sulfur in lube oil. It seems that some sulfur compounds act like vulcanizing sulfur in rubber: e.g. they improve it. However, what Exxon had to do to produce an ideal lube oil, like Mobil 1 PAO WITHOUT any sulfur, was to treat it with catalysts under pressure to remove the bad molecules, including essentially all the sulfur. Sulfur in lubricating oil was not improving its lubricity. What it did was to improve its resistance to breakdown by the other bad molecules that mostly contain nitrogen or doubly-bonded molecules (benzene-like).
Benz made gasoline-powered engines as far back as somewhere in the 1960s with injector pumps that appears virtually identical to those used in my Benz diesel engines. Gasoline has much less lubricity than diesel, any diesel.
I really question any research that says that sulfur is a lubricant. It's probably acting like a cross-linking agent between some molecules that therefore make them appear to be more like heavier molecules (e.g. like the adjacent lube oil molecules they were distilled from). Sulfur itself is not doing any lubrication. I'll bet even low sulfur kerosene would have enough lubrication properties to satisfy most injector pump requirements. Even water is a pretty good lubricant.
Ralph
   / New Low Sulfer Diesel in 2006 -PROBLEMS? #57
I emailed Kubota about using ultra low sulfur fuel in my 2000 bx2200. I had a phone msg today, that my engine (tier 1) should be used with the road fuel due out in 2007 (tier 3).
   / New Low Sulfer Diesel in 2006 -PROBLEMS? #58
Oh what the heck. If your worried about lubrication. Just pour some Mystery Oil or tranny fluid into the tank with each fill-up.
   / New Low Sulfer Diesel in 2006 -PROBLEMS? #59
From Diesel VS Heating Oil you said:</font><font color="blue" class="small">( I just got a msg from Kubota concerning the use of the low sulfur onroad fuel (tier 3) to be in placce by 2007. It should not be used in my BX2200, made in the year 2000 (tier 1 engine). I guess I will have to look for an alternitive to buying at the gas station.
)</font>
in this thread it seems you meant to say should NOT be used. John
   / New Low Sulfer Diesel in 2006 -PROBLEMS? #60
If this is the case, What are the recommendations for the Owner that uses only small amounts of fuel?
Where should they get five or ten gallon at a time?
PALLET OF (5) INDOOR CABINETS (A60432)
PALLET OF (5)...
2020 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A60429)
2020 PRINOTH...
20 LOWBOY BUMPER PULL TRAILER (A55745)
20 LOWBOY BUMPER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2003 PETERBUILT PB330 DUMP TRUCK (A58375)
2003 PETERBUILT...
Takeuchi TL150 High Flow Compact Track Loader Skid Steer (A59228)
Takeuchi TL150...
