New Well
/ New Well #41
Some cities??? I think more accurate to say "many cities" (as far south as Sauk City). Code here says 4' depth for footings in most places, 5' in the upper north. Many places were reporting frost depths at 8-10' this year...so much for global warming around here.
That's just hard to fathom for us Southerners (I'm in MO, which isn't THAT far south). Our footings are normally 18" or so around here, and frost really doesn't make it much more than a foot in really cold winters like this past one.
/ New Well #42
Winter truly set in here mid-November and other than a few days it is still here. I was driving to my turkey hunting spot on Tuesday at 4am and the alert on the truck said "ice possible...drive with caution". I think our 4' frost depths had some safety factor built in thinking that it would never exceed 3'...
/ New Well #43
Last December the temps were in the low -30's - -40F. A normal winter sees us with lots of snow in December and the deep cold in January for only two weeks or so, then it warms up and we get lots of snow the rest of January all of February and March.
/ New Well #44
I like snow and cold, but you guys are making me glad I don't live up north! :)
/ New Well
Yup she gets pretty darn frosty here sometimes. There was a few mornings over the winter when the truck almost didn't start and that's with antifreeze mixed for -45, block heater plugged in all night and out of the direct wind.
So we've had the well operational for several days now, it's got a slight hint of an iron smell but only with the hot water. Its better than the old well and we have noticed a difference just since Wednesday with the water quality, it's getting better by the day. I still have to get the softener dialed in properly.
Have I mentioned that the wife is really really happy? Lol
/ New Well #47
On your hot water you may need to pull and inspect the Anode Rod inside it as it may be gone. IT gets ate up faster with iron bacteria in the water, they loves the inside of hot water heaters & they live fine in hot water. The drain on the heater should also be flushed more often as the iron settles out inside the tanks more. Keeping leached out minerals out of the bottom of the tanks helps overall water quality out of the hot water taps, laundry and showers will fell better.
Mark
/ New Well #48
This should make it clear as mud!
/ New Well #49
I have no idea what the R value of dirt is. The 1" of styrofoam=1' of dirt I got from a construction foreman years ago.
The "R" number isn't important... what matters is knowing that it works.
Thank you.
/ New Well #50
If you have iron in the water, DO NOT use Chlorine/Chlorox/Javex in the wash.
/ New Well
The field test kit the drill operator used showed 1 ppm for iron. What's wrong with using bleach?
Good or bad I don't know but I would think it's not terrible. I shocked the well last night and ran a garden tap for a good chunk of the day today. Just had a shower and the iron smell is not there now, I had lots of suds too so I think I've got the softener pretty close to what we will want. I did close off the softener while running out the javex. After running the outside tap today the water quality seems even better than it was yesterday. I have heard people say that well water gets better the more it's used, I don't know if that's just talk or not.
/ New Well #52
it's true. you have a lot of residue, sediment, etc in the well, from the drilling process, especially a deep well.
Once you've run it for a while, the normal fresh water will replace the 'drilled' water, the well walls will wash clean and the veins that feed the well will wash out and settle in to producing clean water.
this does take some time.
/ New Well #53
Iron in the water and bleach will make all your whites yellowish (skid mark yellow). Conditioned water wont do that.
/ New Well
A neighbor around here has that problem with the skid mark yellow, lol that's a funny but true comparison.
Oldpilgrim, I'm new to drilled wells but what you say makes sense. I would assume that the settling down of everything would take several weeks to a couple of months????
/ New Well #55
good assumption :) :thumbsup:
/ New Well #56
My well was drilled some 15-20 years ago and still pumps real fine silt. It was really bad when first drilled but now almost unnoticeable.
Harry K
/ New Well #57
Harry K
My situation is a lot like yours. 19 year old well. I have a whole house filter to get out the real fine silt. I also need a calcium tank to de-acidify the water as it it's pH is a little off. But with those additions, I get great water.
/ New Well
Got some landscaping in the front finished off, here's the wishing well cover I had mentioned, kudos goes to my FIL for this one. Still need to add a small bucket and rope, just for looks.
/ New Well #59
My drilled well is still pumping a bit of silt after some 20 years. When first drilled there would bea thin layer of it on the bottom of glass of water, now, not enough to really notice.
Harry K
Harry K
2014 Ford Taurus Sedan (A59231)
2014 Ford Taurus...
EZ loader trailer (A56857)
EZ loader trailer...
2013 CATERPILLAR 336E L (A58214)
2013 CATERPILLAR...
2022 Transcend Xplor 245RL 30ft. T/A Travel Trailer (A59231)
2022 Transcend...
2017 Ford F-550 Service Truck (A59230)
2017 Ford F-550...
2013 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A59230)
2013 Chevrolet...
