Newbie
   / Newbie
My schematic says 40amp. I found a 30 but no 40. The diesel start module with the corroded hot is a circuit board. There was no corrosion under the washer so I doubt that was a problem. I cleaned it up and put it back together. Now I have lights. No start. Going to PTO switch next. How do you test these kinds of switches with bat disconnected? Do you look for continuity or what?
   / Newbie #52
I would test them by measuring for a voltage, which would test the wire feeding them too. try to follow the schematic if you can. Any way you can scan and post the schematic. Or a good cell phone photo of it?
   / Newbie
I have a picture on my phone but I don't know how to post it.
   / Newbie
Nowhere on this schematic is there referenced a 30amp fuse so that must be the 40 they refer to. The 30 was good.
   / Newbie #59
agree, if the lights work the inline main fuse is good.
   / Newbie #60
Well i got the email, but the resolution is not good enough to make out anything but the battery at the top and a ground symbol. try texting it, I will send my cell number in a reply to your email
2016 Ford F-550 Venturo HT40KXX 3 Ton Crane Mechanics Truck (A59230)
2016 Ford F-550...
2002 Ford F-550 Crew Cab Landscape Dump Truck (A56858)
2002 Ford F-550...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
DEUTZ MARATHON...
Pat's QH and hydraulic top-link.
Pat's QH and...
DEUTZ MARATHON...
