NH T4.90 Heat/AC Problem
   / NH T4.90 Heat/AC Problem #1
Jackfr
Plymouth, MA
NH WorkMaster 33 Ford F5000 NH T 4.90 Ford 2110 JD555B
Has anyone had problems with a 2017 NH T4.90 Heat/AC? We replaced the Heat valve last year because there was no heat and valve was stuck closed. It worked fine until now controlling the amount of heat/AC. Now it is stuck open so full heat and no AC. It's a real PIA to get to the heat valve to replace it again. I've checked all the fuses for the controls all appear to be good. Any suggestions?
   / NH T4.90 Heat/AC Problem #2
You could install a manual water valve, there are many available hand screw type or cable operated.
We used them in trucks as a low cost repair.
I've been trying to find one but no luck so far. The hose is 14mm ID according to the parts book. Which is a little larger than a 1/2" and smaller than a 5/8".
   / NH T4.90 Heat/AC Problem #4
If you are committed to a manual valve you could disconnect the hose and test fit a 5/8th nipple , if to big than Yeah 1/2 inch(14mm) is a odd size. Guess its a trip to the local hardware to make your own.
Recommend to use brass.
1000 Gallon Supply Tank (A53314)
1000 Gallon Supply...
SHOP HEATER (A55745)
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
EZ-GO Cart (A55853)
EZ-GO Cart (A55853)
2007 Yamaha Rhino 660 (A55315)
2007 Yamaha Rhino...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXELL 150...
