Only in Texas, Don and Harv doing
   / Only in Texas, Don and Harv doing #151
<font color="blue"> "You will see behind the walls, under the dirt and through the layers. It's what makes building so addictive!!!!" </font>
Eddie, you nail the love of building in the above quote.
I decided to take a break today and do some TRACTOR work on the building. I need to remove the vegetation from the future storage slab area and replace it with compacted various sizes and fines of gravel.
Removing the grass and top soil. picture 1
   / Only in Texas, Don and Harv doing #152
picture 2
   / Only in Texas, Don and Harv doing #153
picture 2
   / Only in Texas, Don and Harv doing #154
Picture 3.
Well, that took about 5 minutes.
As soon as it gets a bit cooler (this evening, not in the Fall) I will manually clear around the poles for the beam. /forums/images/graemlins/wink.gif
   / Only in Texas, Don and Harv doing #155
Picture 3.
   / Only in Texas, Don and Harv doing #156
At sunset the storage slab area is cleared of vegetation and topsoil, raked, tamped and watered.
It is now ready to be graveled, leveled, and tamped tight, tomorrow.
   / Only in Texas, Don and Harv doing #157
Looks good Don.
The Maximizer costs a little more per volume than standard sacrete. But it's easier to work with and it has a strength of 5500 psi versus 2500 psi for sacrete.
For anyone using it keep in mind it also sets up in about half the time of sacrete. It cooks. /forums/images/graemlins/grin.gif
I haven't used sacrete since I discovered it when mixing small amounts.
Your concrete looks better than mine. Here's where the electrical and water come up through the slab in the horse barn.
Looks good Don.
I explained to Don that I formed up the beam first. Then I decided where I wanted the water and electrical to come in to the building.
I cut two pieces of pvc at an angle and then drove them into the ground about a foot. This made it easier in this situation than digging out a cavity, roughing in the plumbing, and then filling the cavity for forming and pouring the beam.
Then I cut off the angle cuts and took off with the plumbing and electrical conduit.
This is in the county way out in the country. But I personally don't like water and electrical in the same trench. I ran the electrical about thirty inches deep and the water about eighteen.
A couple of years ago I put an auger through power and water at the same time. It was about a foot deep with direct buried romex and that black water tubing that comes in big coils. What made it extremely interesting was the electrical wasn't on a breaker and straight off the meter. /forums/images/graemlins/blush.gif
The auger came out of the hole automatically when it heard what sounded like a gunshot. I found the tap and cut it hot with bolt cutters. It's no fun hitting water and power at the same time.
2019 TerraGator 7300 Spinner truck (A55302)
2019 TerraGator...
2016 FORD TRANSIT PASSENGER VAN (A56129)
2016 FORD TRANSIT...
2017 Ford F-550 Crew Cab Enclosed Service Truck with Liftgate (A55788)
2017 Ford F-550...
2007 Cat 730 Haul Truck (RIDE AND DRIVE) (A50775)
2007 Cat 730 Haul...
2018 Altec DC1317 Towable Brush Chipper (A55787)
2018 Altec DC1317...
White Loader (A50775)
