Overworked Bx2200
   / Overworked Bx2200 #1
cckjone
Bronze Member
Smack in the middle of nowhere, Maine
BX2200
I'm having a huge amount of fill delivered to level off a area behind the house for entertaining. I estimate it will take around 100+ cubic yards. The closest the dump trucks will be able to get is within 50 feet and the drivers will need to unload in one long pile. At first I was really looking forward to some seat time using the FEL and box scraper but now I wondering if I'll be overworking the 'bota. I don't care how long it takes, and I'm confident the BX will eventually get the job done, but am I stretching the limits here? I have only 38 hours on the BX2200 and it's still bright and shiny...am I overly concerned because I'll probably double run time hours over the next couple of weeks? Should I bite the bullet and pay for a skidsteer rental?
   / Overworked Bx2200 #2
Do you need to relocate the dirt or just smooth/shape it? If relocation is in order I'd move to a different machine. For smoothing/shaping you'll get by if you have time available. I just did 100 tons of crushed concrete (about 50 yards?) with my 790/FEL/Box blade. All very enjoyable but those first few swipes can make the job seem daunting. You'll be able to tell pretty quickly whether or not your tractor is up to it /forums/images/graemlins/smile.gif
   / Overworked Bx2200 #3
It will take a little while but won't be overworking it. Just don't try to scoop the dirt 4 foot high in the bucket.
   / Overworked Bx2200 #4
How many truck loads of dirt will that be? I can move and spread a truck load of dirt in approximately 2 hours give or take with the BX and maybe a few minutes faster with the 2410. J
   / Overworked Bx2200 #5
Something you may want to do is have one or two drivers making repeat trips. This way you can get the pile gone before they back. Kinda depends on how far away they are. Otherwise have several loads delivered each day to keep your pile in the same spot. 50' is better than 60-70-80-90 etc... feet away as the pile gets longer. Just some things to think about and make it more manageable.
   / Overworked Bx2200 #6
I moved one large dumptruck load (I'd guess 8-10 yd) last night. Took me almost 3 HRs, but a lot of that time was moving the dirt 75-100 feet. Plus the ground was very sloped and full of gulleys when I started so I couldn't move very fast.
My 2200 only has 30 HRs, so I'm holding it to half throttle, but that speed still seems to move the loader and tractor well.
If time is not an issue, sure you can move it. If you have to have it done in one day, a bobcat might be worth the money. More HP, more capacity, faster, etc.
Let us know (include pics).
Ron
   / Overworked Bx2200 #7
Sorry, but this seems like a strange question. /forums/images/graemlins/confused.gif It's a tractor, it is made to do work. Yes, you have lots of dirt to move, but it is loose dirt and you have lots of time to do it. The question here should be "Will I be overworked?" /forums/images/graemlins/crazy.gif Of course, if you are planning on doing this kind of work on a daily basis, I would consider trading in on a bigger model /forums/images/graemlins/cool.gif.....Hey, I bet you get tired of sitting before the tractor gets tired of working...have fun and take a break every couple of hours. /forums/images/graemlins/wink.gif Oh yeah, pictures...of you, before and after...the tractor will look the same.
   / Overworked Bx2200 #8
With the FEL, and FROM EXPERIENCE, I can tell you that a tiller or some form of weight on the back linkages will make this job less tipsy at least. I have been slowly moving a very large (20 tons) of dirt with mine and it is a lot better if I attach the tiller to offset the weight on the loader.
The tractor and loader will do this, NO PROBLEM, just the tractor is a lot lite in the butt end. I would suggest a tiller, but also you can get a carry all, make a box and fill it with rocks, that will do the offset
   / Overworked Bx2200 #9
My box blade weighs more than the tiller, so I use it....
Ron
   / Overworked Bx2200 #10
It's a matter of time. You will not overwork your BX. It will take longer than a larger machine though. Personally, I would use my BX. It means more seat time!!!
   / Overworked Bx2200 #11
You can do it...and as others indicated, just be prepared to take a lot of time. And...you're going to need a nice chunk of weight on the BACK of the tractor in order to move full buckets of dirt safely. You can use a box blade for that or a ballast box. (I actually use my BX22's backhoe for that these days) Don't attempt this job with out that weight...and wear your seatbelt.
   / Overworked Bx2200 #12
If you don't rush it , Your machine will do fine . Don't try to grab the biggest load you can get in the bucket,and take it fairly easy in transpost . As you said .. it's for filling an area for entertaining . You aren't filling a burst dyke . Enjoy the whole process ! It's kind of what makes owning a tractor nice . ... You don't have to sweat very hard to enjoy your work . John
   / Overworked Bx2200
I want to thank everyone for the hints and encouragement. I'll use this opportunity to figure out the quirks of using my box scraper and post some before and after shots.
   / Overworked Bx2200 #14
So you will have about 50 to 60 hours on it when done! /forums/images/graemlins/grin.gif What is the problem? /forums/images/graemlins/cool.gif
   / Overworked Bx2200 #15
I moved 80,000 lbs of #2B river rock in 12 hours. THe BX can't be overworked. It will do what it will do. Check your tire presures, put the box blade on and go at it. When you take a break, back it down to high idle (just enough to get rid of the shakes) and pop the hood for cooling. That will be a great workout for the hydraulics right before you 50 (or 60, it's not that critical) hour service.
Good luck, have fun and BE CAREFULL!!! /forums/images/graemlins/grin.gif
   / Overworked Bx2200 #16
I have only 13hrs. of seat time and I have fun everytime I'm in it,so add your weight to the back & enjoy it. /forums/images/graemlins/laugh.gif
   / Overworked Bx2200 #17
The project will take a few hours but you will learn the FEL operation and feel very comfortable driving the unit.
Take your time, go slow, and most of all ....enjoy!
(INOP) JLG E300AJP ARTICLATED MANLIFT (A60429)
(INOP) JLG E300AJP...
2022 Bobcat T66 (A53317)
2022 Bobcat T66...
2009 Ford F-150 Pickup Truck (A59230)
2009 Ford F-150...
2006 CHEVROLET SILVERADO 3500 FLATBED (A58214)
2006 CHEVROLET...
2018 KOMATSU WA200-8 WHEEL LOADER (A60429)
2018 KOMATSU...
Forward 10,000lb Two-Post Electric Auto Lift (A55851)
Forward 10,000lb...
