RayIN
I raised and trained horses for many years; never even considered rounded corners, never had a horse hurt in a square corner.
I have squares and rounds, corners, on our property.I raised and trained horses for many years; never even considered rounded corners, never had a horse hurt in a square corner.
I had a contractor that we used putting in fence and on the bottom of his bucket he welded a steel coupling that fit over the T post and use the bucket to drive the T postI push T-posts down with the loader bucket. It's much quicker with a helper.
Of course, the type of ground may require something more meaningful than a loader bucket.
Treated post just don't hold up like they used to. We built a catch pen with 5x5 treated post and most only lasted 5 years. We found some good used railroad cross ties and they are night and day better. No caps needed neither. We used those to rebuild the catch pen and as brace post and one every so often in running our Cattletough fencing on some of our perimeter fencing .I'm 73 & fenced by myself. We're in Virginia. There are 100+ ways to fence but I did it like here with 1 exception. I used tractor & auger (Danuser w/9" auger&spare bit & cutters).
If you have that...no big deal.
I ran string line on property lines. Only help was my wife I had long pole & a good r****/scope (yes...unloaded). Pole had a level on it. She would hold it & I'd guide her L&R...then stick in ground mark.
Then stakes & string. Start at corner, auger down 2-3ft with PT 9s. go out 10ft each way & auger & another PT9. Then a PT5 w/ galvanized dowel...everything straight&level (level ground)...then X'd heavy galv wire & ratchets.
Now I had starting point.
Then all fencing a PT9 every 50ft, four 7ft heavy T posts between every 10ft. Then red-top woven wire. I wired up a foot (we have horses...they're not going under 1 foot & bush hog can mow under. I wouldn't want even galvanized wire touching the ground.
Every transition I used 3 posts, even a small angle.
Now wire. I used two 2x4s holes drilled & carriage bolts, washers, nuts. Use fence for guide. Idea is clamped tight to wire fence now with come-a-longs & ratchets I pulled so tight you could play a tune on it. Galvanized staples hammered in.
Corner posts I poured in quikrete. Others a 7ft tamping iron. T posts pounded in w/ tamper (good exercise).
18ft gates were fine for me.
Very top used T post insulators & post insulators, white flat elec. ribbon with solar charger. A driven ground plus I connected ground to fence.
I've never fenced but figured it out.
