Photo comparison: NH, Kubota, Branson, JD, etc
   / Photo comparison: NH, Kubota, Branson, JD, etc #81
Bucket front view.
   / Photo comparison: NH, Kubota, Branson, JD, etc #82
Right side of tractor.
Hoses are protected, control operation is vertical.
Controls stay with tractor when loader is removed
   / Photo comparison: NH, Kubota, Branson, JD, etc #83
Bob - On the CK30, the hoses aren't coming off the valve, which is built into the right fender. The hoses come off the block that's just for connection. I think if they had put on rt angle connectors, it would have been more difficult to connect, and mybe not had enough slack to run it when you are attaching it. I agree that hoses that project up would really not be a problem as far as my uses go, even in the woods. But I also don't really like the way they look. In the end though, when it comes to tractors, what looks best is what works best!
   / Photo comparison: NH, Kubota, Branson, JD, etc #84
Great thread Bob /forums/images/graemlins/wink.gif
Here's my contribution:
JD 790 w/ 70 loader. C shaped light duty bucket. Contents sold seperately. Note that the 70 loader is no longer sold with the 790 /forums/images/graemlins/smile.gif
   / Photo comparison: NH, Kubota, Branson, JD, etc #85
790/70 from further away /forums/images/graemlins/smile.gif
   / Photo comparison: NH, Kubota, Branson, JD, etc #86
FEL control lever. Mounted below seat (fender), stays with tractor when FEL removed and has horizontal motions /forums/images/graemlins/smile.gif
   / Photo comparison: NH, Kubota, Branson, JD, etc #87
RH view. Ingress/egress is tight but possible /forums/images/graemlins/smile.gif
   / Photo comparison: NH, Kubota, Branson, JD, etc #88
And finally, the LH side showing the FEL connections which are behind the loader frame (protected) /forums/images/graemlins/smile.gif
Rob, in your last picture that shows the connections on the left side of the frame . . . is that rigid pipe or is that hose that is shown to the right of the connections? It looks like pipe but I can't really tell. Do those connect up to hoses that run forward to power the loader?
   / Photo comparison: NH, Kubota, Branson, JD, etc #90
I thought I'd throw in the little guy for comparisin too.
Tractor is a Kubota BX2230, Loader is the Kubota LA211 Loader.
This is the right side of the bucket, light duty, by definition.
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
MASSEY FERGUSON 492 TRACTOR (A51406)
MASSEY FERGUSON...
LOT NUMBER 51 (A53084)
Peterbilt 377 Semi-Truck (A53472)
Peterbilt 377...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
