Plasma Chart?
   / Plasma Chart? #1
CDN Farm Boy
Ottawa Ontario
Kubota B3300SU
Can anyone provide me to a link to a chart for settings for a plasma cutter?
I'm using an Everlast PowerPlasma 50 with hand-held S45 torch. I got the machine for Christmas and just finally got to fire it up today. Literature that came with it isn't helpful. I'd have thought it would have a chart like on the inside of my mig, ie: Thickness - amps - air - travel speed. Or is there some other way to figure out what settings to use?
Thanks
   / Plasma Chart? #2
Found This one via a google search . There were a lot of others also :
Fred H.
   / Plasma Chart? #3
You should contact the manufacturer of your plasma cutter....there is a rep on the Everlast thread that should be able to help you out. Using a chart from another manufacturer will likely result in dross, warpage and overall ugly cuts. Each torch manufacturer's torches have different energy densities , power levels and sets of consumables that will cut at different heights, cut speeds and power levels.
Jim Colt
Thanks
   / Plasma Chart?
Fred H.
I spent 45 min searching different word combinations and didn't once find anything thicker than 1/8". Most charts I found listed from 10ga down to as thin as 28ga. I can't imagine ever wanting to use a plasma cutter for something I could do with snips.
   / Plasma Chart?
Jim, I will certainly be trying that. I'd have contacted tech support @ my dealer but can't reach them till Tues due to the long weekend.
   / Plasma Chart? #6
Basic rule of thumb is 10 amps per 1/8": 1/8" thick = 20 amps, 1/4 = 30a an so on. Air pressure I use is between 55 and 65 psi on the gauge with the switch in the constant flow position.
   / Plasma Chart? #7
What Boomer1025 Wrote is How I run mine , which is a off brand import . Air pressure as He wrote is set with the gun trigger pulled . :thumbsup:
Fred H.
   / Plasma Chart? #8
The air pressure is going to depend upon the torch you are using. If you have the new PT60 torch or the S-45 torch. The S-45 will run 72 psi ideally. The PT 60 will take more up to 80 psi. The S45 units include a flow gauge which simplify setting based on constant volume. You may not have downloaded the latest version of the manual from the website. I am not sure which manuals come with the Canadian versions, but the manuals are on our US website here: http://www.everlastgenerators.com/sites/everlastgenerators/files/downloads/PowerPlasma-50-2013.pdf
The manual will be updated soon for the PT 60 torch. They are similar to the S45's but do offer increased cutting ability on the top end.
Unless you use step down the size of the consumables, plan on using 40-50 amps for the stock consumable .9 or 1.0 mm size. It will cut fine with a fairly narrow kerf. But you can go down to .6 mm with various consumables available for those torches if you need a narrower kerf. Stepping down the amperage with too large of a consumable hole will only lead to arc instability and snuffing of the arc. Using too low of air pressure will too. The best thing to do is keep the amps and air pressure up to or the the maximum rating of the consumable. The PT60 torch is backwards compatible with the S45, if consumables are replaced as a set, including cup. But not the other way around.
The above stated rule of thumb does work fairly well for most hand cutting. Up to 1/8"=20 amps, and for every 1/8" additional thickness, add ten amps. But then again, if you have a .9mm consumable use it at 40-50 amps (the amp range rated for that diameter). The biggest difference is the kerf.
   / Plasma Chart?
Thanks for that information, very helpful. Mark, thanks also for the link to the manual -- WAY better than the crappy 5 page one that came with my machine. I will be suggesting to Duncan for improved manuals to be included with the machines up here.
How does this apply when trying to cut thicker material? Using the rule of thumb, with my 50A machine I should be able to cut 1/2" with it maxed out which is fine the majority of the time. The website says max cut of up to 1". Yesterday I was trying to cut a 15" C channel for a LPGS I'm building that the flanges were 1" at the thickest point.
   / Plasma Chart? #10
It will cut 1", but it will be very slow going, set it to 50a and set the air pressure to 72 psi like Mark said and give it a try. It won't be a nice clean cut. I'm not sure if you got the air flow gauge with your PP50, I didn't get 1 with mine. I set mine up using the post air flow switch, flip the switch to the constant on position, set the pressure on the air gauge, then flip the switch back. I believe Mark done a video on this model that's posted on the Everlast site somewhere. I also keep the post flow at 30 sec, unless it's a long cut, then I'd turn it up to 1 minute, helps keep the torch cool after the cut.
   / Plasma Chart? #11
The cut is rated at 3-5 inches, per minute, with fresh consumables and clean, dry air. 1/16" standoff height. (edge cut). As far as maximum cut the tech specs say 7/8"max severance. The blurbage up top does mention 1" on our site, but probably a mistake on my part when I was setting the page up with the information and typing it based off of memory (faulty). I will make sure it gets changed tonight. There are basically 3 cut capacities we typically refer too. Maximum severance cut (7/8") which is the maximum reasonable cut you can expect and it still come apart if you are patient enough. There will be dross and it will not be a pretty cut compared to lesser thickness cuts. Maximum clean cut capacity. This is where the unit will cut at a slower speed, but still yield a decent cut with less dross and clean separation of the metal. Then you have the average daily cut capacity. In short, this is the maximum thickness you want to cut on a regular, daily basis for reasonable speed hand cutting.
   / Plasma Chart?
I've been using my plasma a bit more lately working on a grapple for my existing bucket. Came back to this thread since I couldn't remember what I was doing. A couple more questions have come up:
Roughly speaking, how long should the consumables last? Can anyone give me a guesstimate on how many feet of cut I should expect from a set? They seem to wear out quicker than I'd have expected. I'm cutting 3/8" plate, 40A & 72ish psi as per recommendations here. Lots of clean, dry air.
Should I be replacing both the tip and the electrode at the same time or should one outlast the other?
   / Plasma Chart? #13
Replace what is worn. Electrodes typically wear slower than the tips. A lot of circumstances affect cut life.
One thing, I do know of a OEM Italian source of consumables here in the US for the torches that do seem to somewhat outlast our OEM Chinese made ones. (Torches are made by Tec.mo in Italy and by Innotec in China under license). Google Plasmadyne . Their number will pop up next to a statement saying this location permanently closed. Ignore that. They also have a E bay site...but somewhat difficult to navigate to find what you want.
Call them. They have great prices too and additional configurations of the consumables and sizes. They seem to be decent enough people out of MO.
   / Plasma Chart? #14
Just realized you had S-45. Same thing applies...call them. They have those as well. The newer ipt 60 torches last longer on the consumables for sure.
   / Plasma Chart?
That's what I have been doing but don't know if I 'should' be getting 10' of cut or 100'.
Thanks. I'll look them up as I need to order some soon. I can get a 180 pc set from Duncan (35 tips, 35 electrodes, 5 caps) which puts it at about $3.75 CDN per tip/electrode set. No idea if that's good or not
2013 JOHN DEERE 772G MOTORGRADER (A60429)
2013 JOHN DEERE...
2003 Pierce 75ft Ladder Fire Rescue Truck (A55852)
2003 Pierce 75ft...
2016 Ford Explorer 4WD XLT SUV (A59231)
2016 Ford Explorer...
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A59905)
2007 FREIGHTLINER...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2016 JOHN DEERE 35G EXCAVATOR (A60429)
2016 JOHN DEERE...
