Pole Barn Project Pics 40x72x14
   / Pole Barn Project Pics 40x72x14 #121
Keving, Those who actually have it call it LYSDEXIA!
Pat
   / Pole Barn Project Pics 40x72x14 #122
Keving: Great pics & Thread!
On the ridge vent: Your barn is probably exposed enough to warrant a much broader cap, since clearly the wind is driving the snow in. Caps are made in a variety of widths to withstand more or less driven snow/rain. If you can couple that to a ridge vent that will help equalize the pressure you will reduce the infiltration.
If you go the route of sealing the existing cap, you will want to put on a cupola (or three!) or series of turbine vents to ventilate the attic. Otherwise you will have condensation accumulating up there and molding/rotting things. Besides, it will keep the barn much cooler in the summer.
All the best,
Peter
P.S. I can't tell from your pictures, but it looks to me as if the barn is missing screening on the ridge vent. To keep the wasps and bees out, you will probably want it.
   / Pole Barn Project Pics 40x72x14 #123
On a thread entitled "polebarn" I was expecting a few posts, no walls, and a tin roof. Holy smokes! I'd call this more of a luxury garage (network cabling suggests hispeed internet) than a pole barn. If a fella is going to trade his wife for a barn, this would be the one! :)
   / Pole Barn Project Pics 40x72x14 #124
It sounds like your builder did not install any closure(s) under the cap?
FWIW..Under the ridge cap on our barn I installed alternating 3ft lengths of pieces of foam closure with a vented closure strip (looks like industrial brillo pad like material). Nothing blows in/under the ridge cap w/this stuff.
   / Pole Barn Project Pics 40x72x14 #125
It looks more and more like the builder's shortcut will be an ongoing problem for the owner. The ridge vent just was not done well, irrespective of any comments about how he may have done a hundred of them that worked, this one doesn't.
If satisfaction cannot be had from the builder redoing it and getting it right and something like turbine vents are selected as a fix, then the ridge vent needs to be permanently sealed. Turbine vents work very well and will draw out a large volume of air when the wind blows and a decent amount through convection when there is solar heating of the roof, even with no wind blowing.
The reason the ridge venting needs to be sealed off with turbines is that the partial vacuum pulled by the turbines will suck in air through all openings, including the ridge vent. Sucking air in through the ridge is NOT A GOOD THING and will ruin the performance of the venting system.
The best performance is when incoming air enters as low in the attic as possible, typically from one of two sources. IF the space below the attic is conditioned then the attic vent air needs to come in around the eves. If the space below the attic is not conditioned and it is desired to get some ventilation through it then ceiling openings will let the hottest (ceiling height) air be pulled up into the attic and exhausted at the turbines. Both air inlet sources will allow the turbines to sweep out the hot air from the attic, assisted by natural convection.
If ventilating the spaces below the attic is desired then provision for airflow from out doors, low in the outer walls is best and will reduce stored (stagnant) air.
Pat
Walls are now covered and painted. It sure brightened it up!
   / Pole Barn Project Pics 40x72x14 #128
I'm with mudcat. Looks great, but I'm wondering how much paint that OSB soaked up to give you that nice finish?
Eddie
Eddie
Eddie & Mudcat,
It took one coat of Kilz2 Latex (10 gal) and two coats of this killer paint (14 gal)
   / Pole Barn Project Pics 40x72x14 #130
Hey Keving,
Regardless of the issues that you have encountered, you have a great looking barn. Once you have it all sealed up and everything in it's place, you will have years of enjoyment ahead of you.
Best of luck on solving your eave leaking problem
Mike
2008 VOLVO EC460CL (A52472)
2008 VOLVO EC460CL...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
1999 Ford RV , VIN # 3FCMF53S2XJA29020 (A51572)
1999 Ford RV , VIN...
