Portable 55 gallon diesel fuel storage
   / Portable 55 gallon diesel fuel storage
I suppose now you are going to want to see pictures of the cannon in the background because you are contemplating one of those also?
   / Portable 55 gallon diesel fuel storage #22
No, I have adequate firepower but the wooden barrel looks interesting...
   / Portable 55 gallon diesel fuel storage #23
I need a new cannon. How bout some pics?
Your on your own w/ the wooden barrel. Try craigslist.
   / Portable 55 gallon diesel fuel storage #25
My system got drained a few days ago.... Paid a friend 50 bucks to refill it and 5 days later its empty again... so I have a major leak somewhere. This is my house by the way not a vehicle so a bit harder to locate. I am sure its a failed solder joint somewhere though w/ the speed of the leak. Either way I would rather fix this 15 year old system for 150 bucks, than replace it for 2500 even if the fix only lasts another two years or so... there is always the chance it can last another 10 years.
A 15 year old system is much less efficient than the newer systems. On a system that old, replacing it with an energy efficient model would pay for itself in less electricity used. I replaced one in my old house that was about that old with a high efficiency one and larger capacity. My electricity bill was running $400-450 per month and the AC ran almost all the time to cool the house to 78 degrees. The new unit would run 30 minutes at most and be off for an hour or more. Electric bill went down to around $150 per month.
I pay .08 cents per Kwh here in the city, in a 1400 square foot ranch... during the hottest of times w/ ac running near non stop I still have not had an electric bill over 150 dollars... I don't plan on being in this house for more than another 48 months, preferably less. If I don't sell it, then it will be a rental, either way efficiency is not on the need, or the want list. It just has to work, and be cheap.
I am a jack of all trades, and a master of not a single one of them.
the second picture was actually a video in case you didn't notice.
   / Portable 55 gallon diesel fuel storage #30
Not sure if this thread went to cannons or back to the 55-gallon diesel storage.
I'm looking for the 55-gallon fuel storage too.
I was at an older farm that had an old oil furnace tank atop of a steel rack 7ft high. It used simple gravity with two shout-off valves. The tank could hold about 500 gallons. I thought about just placing the 55-gallon drum up on a steel rack like below and gravity feed the fuel to the tractor tank. NorthernTool has one for $1K. That is nuts for a 55-gallon metal or HDPE plastic tank and some welded angle iron.
   / Portable 55 gallon diesel fuel storage #31
A friend stopped by after cleaning out a storage room at his self storage facility and had a couple of Mack Truck frame mount fuel tanks that were new and never installed and was taking them off to his barn attic in the hopes of a future use. I suggested that we make them into fuel transfer tanks with a set of caster wheels mounted below for easy mobility in the shop. I made one and have used it for the past eight years or so. The tank stores up to 50 gallons and is extremely handy to move around. I used to have a skid-mounted 100 gallon tank but everyone could see it outside my garage. Decided that indoor was safer and more secure given the old 'out of sight, out of mind' approach. I'll take some pics tomorrow while waiting for my delivery and post 'em up here.
So I used it for the first time the other day and there was ALOT of junk left in the MR. Funnel when it was done. Glad I used it or that crap would have been added to my tractors fuel tank. However the MR. Funnel was slower n **** and not fun to use, I ended up making quite the mess. This has me wanting to add a filter to the set up right behind the nozzle. Its 3/4 NPT. will this rotary pump be able to put out enough pressure to force the fuel through a filter? Anybody got a link to a cheap filter that I could easily add to this set up?
That was the original plan. I was going to use this set up and just raise the drum onto the metal stand that I already have. Its a rectangular flat top though as it a really old play set. However in my county you have to have more than 10 acres to have on site fuel storage like that so I figured it would just be better to keep the stuff inside. That's why I put the drum upright and on a dolly.
   / Portable 55 gallon diesel fuel storage #34
Here is my set up. Have more $$ in the pallet than the whole tank and pump set up. With fuel prices falling, I'm going to sell the kids and get the tank filled. Free delivery if I buy 100 gallons.
   / Portable 55 gallon diesel fuel storage #36
I didn't end up buying that one.... I bought one that was a bit cheaper. I figure I will not have to replace the filter for almost a decade at 100 gallons a year.
   / Portable 55 gallon diesel fuel storage #38
The cheaper Goldenrod may not get water. Condensation is always a problem for us that use minimum fuel but store large amounts.
A few dollars now may save lots later, JMHO
   / Portable 55 gallon diesel fuel storage #39
Long term storeage of diesel brings up issues of algee growth... for that reason, a couple 5 gallon cans when I need them works for me.
Just because you have 55 gallon capacity doesn't mean you have to fill it... my dad used to get the 25-30 gallons we would use in a summer each spring in his drum and just used cans thru the winter if that got used up.
I dont think i will have MUCH condensation. I plan on putting a blanket around this one as well to just help a little bit, but its stored inside. I have yet to see very much condensation on anything in that barn so I doubt it will be a huge problem.
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
2016 Dodge Journey SUV (A59231)
2016 Dodge Journey...
2011 GENIE Z-45/25J ELECTRIC BOOM LIFT (A60429)
2011 GENIE...
2020 Ram 3500 4x4 Ext. Cab Pickup Truck (A59230)
2020 Ram 3500 4x4...
UNUSED FUTURE BD98-98" HYD BACKHOE DIGGER (A60432)
UNUSED FUTURE...
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
