Pouring hydr oil from a 5-gal pail
   / Pouring hydr oil from a 5-gal pail #11
Me? I'm a Real Man (tm) and only use 55 gal drums that I lift over my head and aim the stream to hit the fill port without so much as a funnel! Arr! Arr Arr! Whilst bellowing like Tarzan!🌴
Oh yeah, right - I just use a hand pump to get 95% of it, consolidate the remainders into one pail and then pour that into the fill port... Pouring from a 5 gal pail into anything but a large, low tub is pure hell, IMO, so I just avoid it.
Spout at top as mentioned, then roll spout as pail empties. No tools, one opening, done!
That's how I did it before.
Then I had to use an 5-gal pail to carry diesel, so I put a fuel can vent in that oil pail so it would pour diesel faster and neater.
Then the next time I had to pour from a new 5-gal of hydr oil,,,, knowing how it was easier, faster, neater,,,, I put a vent in from new.
   / Pouring hydr oil from a 5-gal pail #14
I bet if there was a vent you wouldn't invert.😉
Anyway this is just a shop tip, not a requirement.
And you do have to plan ahead and have the vents on hand, and proper holes etc.
If you were drilling a gasoline can, maybe 31/64??
But I've been drilling 1/2" and they fit tight and don't spin etc.
If it's a 5 gallon bucket(s) I'm only pouring once each... No way..
If it's a 5 gallon bucket that gets reused like a 5 gallon gas/diesel can... then yeah that would make sense.
sure, you can just drill the hole & discard the empty pail, if you got too many piling up.
I have a few different pcs of eqpt, and poured about 2quarts out thus far.
So the pail is still quite full.
I imagine it will be a few quarts of oil here and there ...... over the next months or year.
I'm _certain_
that I will be pleased to see this little yellow vent
each time I pick up this pail
until it's empty.
   / Pouring hydr oil from a 5-gal pail #16
Whether it's engine oil or hydraulic oil - it's much easier to use a funnel on my M6040. I have a metal funnel with two foot flex spout. I wire it up to the FEL or top link so I don't have to hold it.
It takes 16+ gallons of hydraulic oil. Soooo..... pour until tired - rest a spell - pour some more - etc.
   / Pouring hydr oil from a 5-gal pail #17
I used to lift one 5 gal bucket under each arm but then I bought this:
   / Pouring hydr oil from a 5-gal pail #18
I'm still real tough. I pour three fives in a 15 gal bucket. Then I pour the 15 gallons in the machine. That way I only have to handle one bucket when pouring.
Good one!!!
I'm still a wuss. I buy mine in 2.5 gal jugs. :ROFLMAO:
   / Pouring hydr oil from a 5-gal pail #19
The way I do it is the correct method. A 5 gallon pail and a funnel. You dump about a gallon in carefully, your arms get tired, it slips and about a quart dumps all over the place. You finish after a long string of colorful words, then you have an excuse to clean the back of your tractor.
Keeping a pump clean, wiping up the drips etc as you move it from pail to pail could be more effort than this method
pouring-hydr-oil-from-a-5-gal-pail.460686
. And overshooting the hole as you calibrate your high-pour. And mess from overshooting the hole as you adjust. Cleaning a funnel takes time too (before and after).
I’ve done all of this.
(#wasnt.born.yesterday)
Drill a 1/2" hole and snap this vent in first thing,,,,,,,
just sayin’….this still looks pretty easy. Agreed its most attractive to those who already have a bag of yellow fuel can vents onhand.
1999 CHEVROLET C7500 UTILITY TRUCK (A56129)
1999 CHEVROLET...
MISC LOT (A55745)
MISC LOT (A55745)
2013 CAT 950K WHEEL LOADER (A53843)
2013 CAT 950K...
2006 Chevrolet Silverado 1500 4x4 Pickup Truck (A53422)
2006 Chevrolet...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
2004 INTERNATIONAL 4400 SBA 4X2 LANDSCAPE TRK (A52706)
2004 INTERNATIONAL...
