Problem with Ford 3000 tractor..
   / Problem with Ford 3000 tractor.. #11
I went through the same thing last summer on my 3000. Changed most of the electrical system and replaced fuel cap and still had the problem. Ended up being just a clogged fuel petcock. Should be easy to check.
   / Problem with Ford 3000 tractor.. #12
Next time it dies.. pull a plug wire and see if you have spark.. if you do, then check fuel flow. The MS carbs had a bowl drain to check.. not sure about the holley carbs..
Soundguy
I think i'm going to try the coil. I've tried some of the other suggested fixes and nothings resolved it so far. But now I have a nice clean carb and perfect flowing fuel system. :)
Is a N/H dealer the only place to get a new coil fror it? Or will an auto parts store etc. carry them as well? Is there a coil for something else that could substitute for it ? I apologize for my ignorance in this area. Thanks to thoes who are helping me I really appreciate it!
   / Problem with Ford 3000 tractor.. #14
Mine started doing that crap and went down hill from there.
Coil would be the first thing. I hope that's all but of all things, my dang freeze plugs had to be replaced. Thought everything was fine. I had to spray a little starting fluid in it until it would stay running then all of a sudden water went everywhere. Three hundred in labor and 2 dollars in parts. Then the leaks started everywhere and hoses... One thing after the next. Finally broke down and bought a new one. Got tired of losing days working on the tractor instead of working on my place.
Hope that is not your trouble.
excavator trenching bucket- one bucket per lot (A56436)
excavator...
Case 930 Tractor (A59814)
Case 930 Tractor...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A56438)
Ditch Witch 6510A...
1983 INTERNATIONAL S SERIES WATER TRUCK (A52707)
1983 INTERNATIONAL...
Peterbilt 377 Semi-Truck (A56438)
Peterbilt 377...
*Selling at Royal Auction Zephyrhills, FL Location* (A59228)
*Selling at Royal...
