Problem with Ford 3000 tractor..
   / Problem with Ford 3000 tractor.. #11
I went through the same thing last summer on my 3000. Changed most of the electrical system and replaced fuel cap and still had the problem. Ended up being just a clogged fuel petcock. Should be easy to check.
   / Problem with Ford 3000 tractor.. #12
Next time it dies.. pull a plug wire and see if you have spark.. if you do, then check fuel flow. The MS carbs had a bowl drain to check.. not sure about the holley carbs..
Soundguy
I think i'm going to try the coil. I've tried some of the other suggested fixes and nothings resolved it so far. But now I have a nice clean carb and perfect flowing fuel system. :)
Is a N/H dealer the only place to get a new coil fror it? Or will an auto parts store etc. carry them as well? Is there a coil for something else that could substitute for it ? I apologize for my ignorance in this area. Thanks to thoes who are helping me I really appreciate it!
   / Problem with Ford 3000 tractor.. #14
Mine started doing that crap and went down hill from there.
Coil would be the first thing. I hope that's all but of all things, my dang freeze plugs had to be replaced. Thought everything was fine. I had to spray a little starting fluid in it until it would stay running then all of a sudden water went everywhere. Three hundred in labor and 2 dollars in parts. Then the leaks started everywhere and hoses... One thing after the next. Finally broke down and bought a new one. Got tired of losing days working on the tractor instead of working on my place.
Hope that is not your trouble.
John Deere 5105M (A53317)
John Deere 5105M...
1995 Stoughton Enclosed Dry Van Trailer, VIN # 1DW1A5323SS900663 (A57453)
1995 Stoughton...
*Selling at Royal Auction Zephyrhills, FL Location* 12 (A59230)
*Selling at Royal...
2019 GALYEAN 150BBL STEEL (A58214)
2019 GALYEAN...
2020 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A59575)
2020 FREIGHTLINER...
Mini SUV (A59231)
Mini SUV (A59231)
