Proud New Owner of YM1610 2WD
   / Proud New Owner of YM1610 2WD #21
If u get the numbers u do Winston than that I. Correct!! I haven't messed with mine other than reading on the. Battery.but if one side is ground then wen I touch one probe to hot aide and have other on the block u should still get the 18v if ur ground on block is good right?
   / Proud New Owner of YM1610 2WD #22
What you are saying sounds right but I only get ac voltage by touching the two probes. None when touching either probe to ground.
Just back from work and first job was to check AC voltage coming off the Dynamo.
Tested at 1800rpm and reading is 25.4v AC. So I assume the dynamo is ok ?
Does this now point to a regulator issue or a bad battery ?
   / Proud New Owner of YM1610 2WD #24
regulator.
If your battery will sit for a few days and still read more than 12.6v its good. If it starts the tractor its good. IF the Alt is putting out greater than say 18-20v unregulated its good, the last thing is the regulator, which is the most common failed part.
   / Proud New Owner of YM1610 2WD #25
I can add absolutely nothing to the advice givin all been spot on other than make sure the belt is not slipping and plus these guys know dynamos where as I know nothing about them so I can say welcome to the group! I have a good friend with a 1610 so could maybe answer some detailed questions about controls etc if the need arises he may have a manual also I can ask.:thumbsup:
regulator.
Thanks clemsonfor, I'll leave the battery standing for a couple of days and check the output.
Thanks Car Doc - I've ordered a 1610 operators manual from Hoyes which should be here in a few days.
   / Proud New Owner of YM1610 2WD #28
Welcome and sounds like you are off to a good start!
Correct - I do have a gauge and just tested it using the method you (Winston1) and California described and the gauge did move when grounded - New sensor on order !!
The battery still reads 12.4v after a couple of days, checked the alt output again and fine, so have ordered a new regulator.
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
NEW Wolverine Skid Steer Bucket Forks (A53002)
NEW Wolverine Skid...
2009 INTERNATIONAL PRO STAR (A52472)
2009 INTERNATIONAL...
2015 Dodge 5500 4X4 Bucket Truck (A52748)
2015 Dodge 5500...
