PTO driven weedeater type gadget
   / PTO driven weedeater type gadget #11
Both links I posted show mowers that roll around fence posts.
   / PTO driven weedeater type gadget #13
I don't have a PTO model but I do have a push behind with a 6.5 h.p. Briggs. It uses the same line size .155 for cutting. It will definitely do a job on tall weeds and grass. However, any solid objects hidden in the grass (piece of wood, old metal fence post etc. will tear the line pretty quickly. Have plently of replacement line on had. I buy mine in 50' rolls at Menard's. I use the Gator Brand. I have some places on my property that need to be cut that are to close to a drop off which gives me the pucker factor. Use the high wheeled string trimmer for those areas. DR Power Equpment offers several models including one that is self-propelled and I believe uses a.177 size line for cutting.
   / PTO driven weedeater type gadget #15
But you still can't mow out over ditches and banks with it can you.?
   / PTO driven weedeater type gadget #17
I'm working on putting together some ideas I have using the concept of a hydraulically powered weed wacker type of set up, only it will be on the end of a rather long boom that is operated from the operators seat. I have a ditch running parallel with the road that is 5 feet deep. My sickle bar mower is not long enough to reach completely across it. It leaves an unsightly unmowed strip that looks like he!!. Using the weed wacker concept, I can get deep into the ditch and keep it looking clean. If I can make it operate with the same concept of a back hoe, I believe it can achieve what I'm looking for. Perhaps there is something out there that I am unaware. Thanks, Roger
   / PTO driven weedeater type gadget #18
Roger,
How about something like this.
1991 Suzuki LT160 Quad Runner (A59814)
1991 Suzuki LT160...
2012 DIAMOND C  40FT GOOSENECK TRAILER (A58214)
2012 DIAMOND C...
Deere 310L (A53317)
Deere 310L (A53317)
2021 BOBCAT T870 SKID STEER (A60429)
2021 BOBCAT T870...
MORBARK 3400XT WOODHOG HORIZONTAL GRINDER (A60429)
MORBARK 3400XT...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
