Poopdeck Pappy
Elite Member
- Joined
- May 13, 2013
- Messages
- 2,628
- Location
- Dallas, Texas
- Tractor
- Kioti DK50SE Cab, Kubota BX23, Kubota BX2660, Grasshopper 729BT
I've never used a land plane grading scraper (LPGS) but I'm looking to buy one. I've used my Gannon box blade to cut some trails through my property. I'm getting a lot of washboarding on some of the trails. Of course, it's caused by the pivoting of the box blade up and down in the opposite direction of the front of the tractor. With the box blade, every pass exacerbates the problem.
I'm looking at two possible solutions. Either (1) get/build a drag to drag behind the tractor, or (2) buy a LPGS.
My questions about the LPGS are:
1. Does the LPGS suffer the same washboarding as a box blade does?
2. If so, can you unhook the top link on a LPGS and just drag it using the two lower links? This should eliminate the washboarding by allowing the LPGS to be less affected by the pivoting motions of the front of the tractor.
