Questions about hyd angle front plow
   / Questions about hyd angle front plow #31
Zick:
This is my blade in action. Enjoy yours, it is an awesome tool.
Alan
AMR said:
Zick:
Alan
Sweet!
Those are turf tires right, any problems with traction without chains?
   / Questions about hyd angle front plow #33
LBrown59 said:
xxxxxxxxxxxxxxxxxxxxxxxx
Is it Hydraulic or manual angle?
I got a price of $1400 for a new Manual angle blade.
Do you have any idea what a new Hydraulic angle blade cost?
I'm also checking into a used Hydraulic angle blade.
XXXXXXXXXXXXXXXXXXXXXXXXX
PS/up date.
Just got these quotes on 3 different Front Blades.
1* $1900 New hydraulic up/down and angle
2* $1400 New hydraulic up/down and manual angle
3* $1500 Used hydraulic up/down and angle
Now which one to pick?
Always decisions and trade offs.
   / Questions about hyd angle front plow #34
Take the used, as long as it's hyd. angle. You do not want a manual. These things CAN NOT be worn out. They would easily hold up to a tractor twice the HP of the BX.
   / Questions about hyd angle front plow #35
I had about ruled out the Manual thus narrowing it down between the
and the
The advantage of the $1900 New hydraulic up/down and angle blade is I can get the 0% financing on it.
Financing is about 7% on the $1500 Used hydraulic up/down and angle blade.
   / Questions about hyd angle front plow #36
Zick:
Yes, I had turfs on my BX23, traction was never a big issue. I could generally push just as much as I wanted, even up hill. Certainly with those rainy slushy icy events it slipped around some but it got the job done without too much trouble. What I found was that the rears lost traction much less than the front of the machine got pushed around with the blade angled, sometimes I used the blade to steer the tractor.
I have a 13% slope with a hair pin turn on one part of the driveway, because my house is above the road the first pass was always a full blade right down the middle. Then I angled the blade max to one side and went up and down.
Occasionally coming back up I would get sliding pretty good and would just take less of a bite and come back down taking more.
Good luck, we've had no rain here this year, let's hope we get some snow.
Alan
   / Questions about hyd angle front plow #37
Zick said:
I just ordered my BX2350 with the hydraulic blade Thursday. The total was about $1836
Well I just talked to the dealer that I'm trying to purchase the 2 Kubota BX1500 tractors from.
Got a price of just under $1900 for a new front blade with hydraulic lift & hydraulic angle.
Sounds like his price is in line with the price you got.
Thanks for the info.
   / Questions about hyd angle front plow #38
1*I left my BH on for ballast and never had serious traction problems.
AMR
2* I assume you can leave the quick hitch attached but remove the blade if you need to use the FEL .
rpoage
3*It's a good thing the Hyd blade for the BX models attaches to the frame and not the FEL arms.
Zick
1*My plan is to use the tiller as ballast when the front blade is on the BX1500.
2*What*s nice is I don't hafta remove a blade to use the FEL or remove the FEL to use the blade by having a BX23 and a BX1500.
3*Yeah especially for those who don't have a FEL.
   / Questions about hyd angle front plow #39
Hi. Has anyone put a hydralic snowblade on their BXs FEL? Must be a advantage to be able to lift/push the snow if you get big snow walls. Or is the BXs FEL to weak for this purpose?
   / Questions about hyd angle front plow #40
There are threads about fel mounted blades here .
I was reading them recently.
Don't know where right off hand but you can do a search.:)
(1) HD 20ft Free Standing Corral Panel with Feed Bunk (A57453)
(1) HD 20ft Free...
2016 DRAGON SAND CONVEYOR (A58214)
2016 DRAGON SAND...
7ft Workbench (A57454)
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
Miller Air Condition Unit (A57454)
Miller Air...
New/Unused 2025 CFG QK18R Mini Excavator (A57453)
New/Unused 2025...
