MtnViewRanch
Elite Member, Advertiser
- Joined
- Mar 19, 2005
- Messages
- 10,690
- Tractor
- Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
These are what I supply with every Kioti order that uses the rear remotes. ZERO ISSUES no matter what size tractor.what I'm taking from this is the same as I came in with1/2" will probably most likely work, but it may (will?) not be optimal.
Ok, so having a small tractor I don't want to loose any more pressure drop than I need - there aren't that many fittings should I replace some.
what fitting flows the best (lowest pressure drop)? (particularly in 1/2" size, but I'd imagine difference sizes stack up similarly?)
