Recap of New Features
   / Recap of New Features #31
Muhammad
I like it. I do have two questions though. Would it be possible to add a login window on the home page? This would save two steps when logging in. Also, do you have plans to add the read post feature?
   / Recap of New Features #32
Thanks here too,Muhammad,especially for the new background color ! Makes print easier to read....OLD AGE !!!!! dass
<font color=blue>Also, do you have plans to add the read post feature?</font color=blue>
What's that? /w3tcompact/icons/wink.gif
As for the home page login ... it was causing some problems with some of the new code, so we removed it... we'll probably look at adding it again at some point, though.
We'll be adding an "add an update to this review" feature, in time.
   / Recap of New Features #35
Muhammad,
Initially I was lost, but now that I wandered around I found the forum to be even better than before...
The one thing that I really would like to see is the "Polling" function. Lots of times we users would like to get mass opinions on simple yes - no questions...
For example:
Are you an NRA Member? Yes __ No __
If it doesn't suck up too much server space, I think it would be a great addition.
DrDan
   / Recap of New Features #36
Muhammad, new site looks great.
One minor issue which may be related to my rather obscure web browsers - in searching user profiles, partial matches are not returned. What I type is what is searched for. For example, searching for Quebec returns no results. Searching for Quebec, Canada returns 1 result (me). I'm using Konqueror on Mandrake 8.1. (the same thing happens with Galeon and Mozilla). Do not rule out the possibility that I am doing something dumb.
No, we're still tweaking how the search works, so it's not a problem on your end. /w3tcompact/icons/smile.gif For a partial match, put your terms indide asterisks ... for Quebec, enter <font color=blue>*quebec*</font color=blue> ... but remember that this will probably change in the coming days.
   / Recap of New Features #38
Muhammad -- On the user list, would it be possible to use letters instead of numbers...so if I was looking for Harv (not picking on you, old buddy, just an example) I could click on H instead of trying to guess which number he fell under..?
Pete
The user list is ordered alphabetically by default ... but some users decided to use numbers so they show up at the top. Best way is to search since harv would probably be a few dozen pages in on the normal view.
   / Recap of New Features #40
Muhammad
What's that?
I might have called it the wrong thing. What ever you would call a button or right click or something that would take away the (new) and make it look as though you've already read a topic or post without having to open it. When this was discussed earlier I thought something like that was a go. Maybe I just read in something that wasn't there.
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A56436)
2022 Greenworks...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Filabot Spooler (A56860)
Filabot Spooler...
2012 TROXELL 130 BBL STEEL (A58214)
2012 TROXELL 130...
1992 Norris Long Basket Trailer (A60460)
1992 Norris Long...
