Removing t posts
   / Removing t posts #1
Highsmith
Kingsbury, TX
Kubota L2350DT, BCS 853
How do I best use a farm jack (like the one pictured) to remove t-posts? I am thinking I just tie a chain around the post and jack and lift, but there are over a hundred posts and I would like the best method possible. Or should I just buy a Post Popper for ease?
   / Removing t posts #2
I'm guessing you already have a jack, so I'd try this first. Get a section of chain about 2' long and fasten it into a loop. Drop the loop over the post so the links catch the little ridges and then twist the chain into a figure 8 shape. Loop the open end of the figure 8 over the snout of the jack and start jacking. The chain should tighten and pull the post. You may have to lean the jack or brace it some, but I think the quick attachment you gain with the post puller can be duplicated using the chain loop.
   / Removing t posts #3
My experience is that the high lift juack works better than those post poppers. Actually a FEL with a chain is even better.
   / Removing t posts #4
If you have a helper you can use this method....take an old wheel (doesn't matter what size or brand, just a vehicle wheel without a tire on it) and place it close to the post in a vertical position. Wrap a chain around the post as close to the ground as you can and tie the other end to a tractor, jeep, whatever. Put the chain over the wheel and pull. Up comes the post. This is not a speedy way to pull posts by yourself, but with one more person you can do a lot of posts.
   / Removing t posts #5
I suppose Jim is referring to something like this.
But you could get one of these (or build it) for your fel or 3pt. Use it on posts or trees?
   / Removing t posts #6
i've used the farm jack method, the fel and chain method and the post popper. by far the easiest and fastest method is the post popper. i've pulled a lot of posts using the popper and i've never ran into a post that i could not get out using the popper.
   / Removing t posts #7
I'm a FEL and chain guy. Tell a buddy you'll buy him a brew and let him stay on the ground and wrap the chain around T posts and put them in the FEL. You drive the tractor. :)
I get tired of lugging the tractor jack around.
   / Removing t posts #8
   / Removing t posts #9
Well, TxDon, I wouldn't argue that you could do that... but, I'd sweat less in my tractor cab. Now, my buddy... different story:)
   / Removing t posts #10
When I get old I'm going to get a cab.....and a buddy.:D
Tandem Axle Rear Trailer Frame (A55852)
Tandem Axle Rear...
2017 CATERPILLAR 259D SKID STEER (A52707)
2017 CATERPILLAR...
2001 Acura MDX SUV (A53424)
2001 Acura MDX SUV...
WOODS 1033674 SUBFRAME KIT (A57192)
WOODS 1033674...
2015 Cheverolet Tahoe SUV (A55853)
2015 Cheverolet...
TEST YOUR BID BUTTON! (A57192)
TEST YOUR BID...
