Removing t posts
   / Removing t posts #1
Highsmith
Kingsbury, TX
Kubota L2350DT, BCS 853
How do I best use a farm jack (like the one pictured) to remove t-posts? I am thinking I just tie a chain around the post and jack and lift, but there are over a hundred posts and I would like the best method possible. Or should I just buy a Post Popper for ease?
   / Removing t posts #2
I'm guessing you already have a jack, so I'd try this first. Get a section of chain about 2' long and fasten it into a loop. Drop the loop over the post so the links catch the little ridges and then twist the chain into a figure 8 shape. Loop the open end of the figure 8 over the snout of the jack and start jacking. The chain should tighten and pull the post. You may have to lean the jack or brace it some, but I think the quick attachment you gain with the post puller can be duplicated using the chain loop.
   / Removing t posts #3
My experience is that the high lift juack works better than those post poppers. Actually a FEL with a chain is even better.
   / Removing t posts #4
If you have a helper you can use this method....take an old wheel (doesn't matter what size or brand, just a vehicle wheel without a tire on it) and place it close to the post in a vertical position. Wrap a chain around the post as close to the ground as you can and tie the other end to a tractor, jeep, whatever. Put the chain over the wheel and pull. Up comes the post. This is not a speedy way to pull posts by yourself, but with one more person you can do a lot of posts.
   / Removing t posts #5
I suppose Jim is referring to something like this.
But you could get one of these (or build it) for your fel or 3pt. Use it on posts or trees?
   / Removing t posts #6
i've used the farm jack method, the fel and chain method and the post popper. by far the easiest and fastest method is the post popper. i've pulled a lot of posts using the popper and i've never ran into a post that i could not get out using the popper.
   / Removing t posts #7
I'm a FEL and chain guy. Tell a buddy you'll buy him a brew and let him stay on the ground and wrap the chain around T posts and put them in the FEL. You drive the tractor. :)
I get tired of lugging the tractor jack around.
   / Removing t posts #8
   / Removing t posts #9
Well, TxDon, I wouldn't argue that you could do that... but, I'd sweat less in my tractor cab. Now, my buddy... different story:)
   / Removing t posts #10
When I get old I'm going to get a cab.....and a buddy.:D
Polaris ATV (A50324)
UNUSED FUTURE X-HWG72-72" HYD WOOD GRABBER (A57193)
UNUSED FUTURE...
2008 BOBCAT 331G EXCAVATOR (A52707)
2008 BOBCAT 331G...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55851)
2025 Kivel 48in...
2024 WITZCO RG-52 LOW BOY (A57880)
2024 WITZCO RG-52...
(15) 1 RANCH 1RGPM GROUND PROTECTION MATS (A57193)
(15) 1 RANCH 1RGPM...
